need bigger sub
Have the psw10 but now that the rti150's are gone I'm going to need more bass. I'm thinking 4 series, I have a medium room with concrete wall and 30 feet deep? I'm basing this on lsi7's upfront until the 9's arrive in a few days and the 7's go to sur. back.
F-lsi9
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G
What is your actual room size? If it's 30 ft. deep with concrete walls, you'll need a massive sub.
What is your budget?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
budget is five to six hundred or so, and the room size is medium with concrete walls 30ft deep, 15ft wide by 7ft high.F-lsi9
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G -
also I'm only using the first 15ft with the sur. back at the 15foot mark.F-lsi9
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G -
Is this a basement with a concrete floor? If so and if you're handy, consider a DIY infinite baffle design.
Like I said, you'll need a massive sub. Try getting a used Hsu STF-3 or used SVS anything. These subs will be OK until you can get something more powerful.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
carpeted floorF-lsi9
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G -
You probably can get a used Hsu VTF3 mkII for around $600. I have one, and I'm very happy w/it. The VTF3 gives you the option of tuning it at a lower frequency (18hz) by plugging one of the two ports (in comparision to the Hsu STF3--which does not give you this option).
SVS PB 10 is also a very good sub. -
I reccomend the SVS 20-39 PCi.
Video: LG OLED77B4PUA * Sony BDP-S470 * Roku Ultra * APC H10 -
WOW! It only took 4 posts this time to mention SVS!!! You guys are slippin'! :rolleyes:
upgrading subs?.. leave Polk behind. -
I second Peersol!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
