need bigger sub
bigsslim
bigsslim Posts: 17
edited January 2006 in Speakers
Have the psw10 but now that the rti150's are gone I'm going to need more bass. I'm thinking 4 series, I have a medium room with concrete wall and 30 feet deep? I'm basing this on lsi7's upfront until the 9's arrive in a few days and the 7's go to sur. back.
F-lsi9
C-lsic
Sur-lsifx
Sur-B-lsi7
Sub-psw10
PRS custom 24 20th
yamaha5790
yamahaC940sacd
monster 14G
Post edited by bigsslim on
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    What is your actual room size? If it's 30 ft. deep with concrete walls, you'll need a massive sub.
    What is your budget?
    "God grooves with tubes."
  • bigsslim
    bigsslim Posts: 17
    edited January 2006
    budget is five to six hundred or so, and the room size is medium with concrete walls 30ft deep, 15ft wide by 7ft high.
    F-lsi9
    C-lsic
    Sur-lsifx
    Sur-B-lsi7
    Sub-psw10
    PRS custom 24 20th
    yamaha5790
    yamahaC940sacd
    monster 14G
  • bigsslim
    bigsslim Posts: 17
    edited January 2006
    also I'm only using the first 15ft with the sur. back at the 15foot mark.
    F-lsi9
    C-lsic
    Sur-lsifx
    Sur-B-lsi7
    Sub-psw10
    PRS custom 24 20th
    yamaha5790
    yamahaC940sacd
    monster 14G
  • Early B.
    edited January 2006
    Is this a basement with a concrete floor? If so and if you're handy, consider a DIY infinite baffle design.
    Like I said, you'll need a massive sub. Try getting a used Hsu STF-3 or used SVS anything. These subs will be OK until you can get something more powerful.
  • bigsslim
    bigsslim Posts: 17
    edited January 2006
    carpeted floor
    F-lsi9
    C-lsic
    Sur-lsifx
    Sur-B-lsi7
    Sub-psw10
    PRS custom 24 20th
    yamaha5790
    yamahaC940sacd
    monster 14G
  • kingtut
    kingtut Posts: 813
    edited January 2006
    You probably can get a used Hsu VTF3 mkII for around $600. I have one, and I'm very happy w/it. The VTF3 gives you the option of tuning it at a lower frequency (18hz) by plugging one of the two ports (in comparision to the Hsu STF3--which does not give you this option).
    SVS PB 10 is also a very good sub.
  • halo
    halo Posts: 5,616
    edited January 2006
    I reccomend the SVS 20-39 PCi. ;)
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    WOW! It only took 4 posts this time to mention SVS!!! You guys are slippin'! :rolleyes: ;)
    upgrading subs?.. leave Polk behind.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • Joey_V
    Joey_V Posts: 8,586
    edited January 2006
    I second Peersol!
