sub hookup...no sound
beardog03
On the the back of my Cary integrated it has a right and left sub out.
I hooked the sub cable up to one side, ran it to the back of my new SVS PB-10, and let her warm up for 30 min..
Poped in a CD and turned her up..
No sound from the sub...what gives..?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool:
Post edited by beardog03 on
c`mon guy`s...what gives..?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
sub output turned on?dvd player: samsung DVD-HD850
receiver: Denon avr5700
center: polk cs400
fronts: polk rt800i
surrounds: Unknown Polk monitor? series.
sub: svs pb12 isd/v
tv: 46 inch samsung -
it`s a integrated 2 ch amp/pre..
as far as I know it`s always on
I was wondering if the signal has to come from both sides (L/R) for it to workCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Doubtful that both the l&r would need to be hooked up. Have you ruled out a problem with the sub?Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
The Sub Out Is Most Likely Just A Second Set Of Full Range Outputs, Try Hooking Up You Main Power Amp To Them And See It You Have A Signal Coming OutDodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
After which if you are getting a signal you might hook her up the Polk way using the high level inputs and see if the sub works. I am of course giving you all the credit of not being a newb and figuring you plugged it in Bear!!
RT1 -
i know you probably aready tried it. but did you try both left and right sub outs? how about on the rear of the SVS? I just got a subwoofer, and it has a left and right inputs on the rear of it.. and i could only get sound when i used the right input. the left wasn't working or something.
also turn your subwoofer to "ON" and not standby.PolkFest 2012, who's going>?
I tried allof the above..
L/R..only has one input on back of sub, works great on the other gear...
It`s in the on position...I tried it all..no sound
bummer..I really wanted to hear it on the Cary..Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
Any chance you need to set your source to 2 channel vs. 5.1?
it`s a 2 ch integrated tube amp/pre ampCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Jolida JD-100 CDP
SVS PC-Ultra Sub
:cool: -
I know, I meant CD player. My Pioneer allows me to select 2 channel or multi-channel via the OSD.
