sub hookup...no sound
beardog03
beardog03 Posts: 5,550
On the the back of my Cary integrated it has a right and left sub out.
I hooked the sub cable up to one side, ran it to the back of my new SVS PB-10, and let her warm up for 30 min..
Poped in a CD and turned her up..
No sound from the sub...what gives..?
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
Post edited by beardog03 on
  • beardog03
    edited January 2006
    c`mon guy`s...what gives..?
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • karpiel666
    karpiel666 Posts: 173
    edited January 2006
    sub output turned on?
    dvd player: samsung DVD-HD850
    receiver: Denon avr5700
    center: polk cs400
    fronts: polk rt800i
    surrounds: Unknown Polk monitor? series.
    sub: svs pb12 isd/v
    tv: 46 inch samsung
  • beardog03
    edited January 2006
    it`s a integrated 2 ch amp/pre..
    as far as I know it`s always on
    I was wondering if the signal has to come from both sides (L/R) for it to work
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • unc2701
    unc2701 Posts: 3,587
    edited January 2006
    Doubtful that both the l&r would need to be hooked up. Have you ruled out a problem with the sub?
    Backburner:Krell KAV-300i
  • hoosier21
    hoosier21 Posts: 4,428
    edited January 2006
    The Sub Out Is Most Likely Just A Second Set Of Full Range Outputs, Try Hooking Up You Main Power Amp To Them And See It You Have A Signal Coming Out
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited January 2006
    After which if you are getting a signal you might hook her up the Polk way using the high level inputs and see if the sub works. I am of course giving you all the credit of not being a newb and figuring you plugged it in Bear!!
    RT1
  • danger boy
    danger boy Posts: 15,722
    edited January 2006
    i know you probably aready tried it. but did you try both left and right sub outs? how about on the rear of the SVS? I just got a subwoofer, and it has a left and right inputs on the rear of it.. and i could only get sound when i used the right input. the left wasn't working or something.
    also turn your subwoofer to "ON" and not standby.
    PolkFest 2012, who's going>?
  • beardog03
    edited January 2006
    I tried allof the above..
    L/R..only has one input on back of sub, works great on the other gear...
    It`s in the on position...I tried it all..no sound
    bummer..I really wanted to hear it on the Cary..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2006
    Any chance you need to set your source to 2 channel vs. 5.1?
  • beardog03
    edited January 2006
    it`s a 2 ch integrated tube amp/pre amp
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • Frank Z
    edited January 2006
    I know, I meant CD player. My Pioneer allows me to select 2 channel or multi-channel via the OSD.
