Anyone using a AVS 2000 voltage stabilizer?
trubluluc
I am looking at picking up a Monster AVS2000 signature series voltage stabilizer from an aquaintance.
(yes I know how we all feel about monster and their f*cking business policies)
It's a used unit so Monster already got their money.
Question is:
I've heard the older AVS2000's made a clicking noise as they worked to stabilize the power,
and I'm wondering if the newer Signature series does the same thing?
-Luc
Question is:
-Luc
Still clicks, not very loud and not very often. Actually mine clicks whenever I turn all of the system on, and just before the AC kicks in during the summer. Thats about it, never hear it click during a movie, or when listening to music.
Jared -
trubluluc wrote:I am looking at picking up a Monster AVS2000 signature series voltage stabilizer from an aquaintance.
Question is:
-Luc
Luc
I don't really know to much about their bus. practice, don't really care, what I do know is that their stuff is priced high, but leaves a larger margin for "getting a deal". I have never purchased any of their cables, IC's, or even their 2250 Power Amp anywhere close to retail....
What I can say as a positive to their audio products is that they are built well. I have never had a problem with their conditioners, and that amp is built like a tank and has replaced my long standing Parasound HCA-1500 in doing the duties for the L/R channel.....
I am currently scouring audiogon, ebay etc. for a "deal" on the AVS-2000, and hopefully it will do the duty it is intended to do and keep the power at 120. When all things are powered in my HT, I have seen dips as low as 108 Volts on my HTS-5100..
If that don't do the trick, then getting a dedicated circuit for my front room will be in order, (should of did this long ago)
Scott -
That is good to hear that the "clicking" noise is not obvious anymore.
Scott, I'm curious what you would call a "deal" as far as the cost of the Signature AVS 2000 ?
I see them often from a specific seller for $579. plus $99. shipping.
-Lucthehaens@cox.ne wrote:Luc
Scott -
i dont even notice the clicking noise any more and i like mine consistantly minus' 2 to 3 volts out of my system as i run a bit hot where i live but when i crank up some music or a movie the juice is sucked up and bam voltage added but i gots to be really cranking it up. i have had my avs 2000 and htps 7000 signuture series for about a year and thought that the extra lights would bother me but after about a couple months i got used to them and quit watching the stabilizer read out :-)Speakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
Fix your electrical problem. Don't put a bad bandaid on it. The monster avs2000 in my opnion sucks ****. I have installed it many times and found nothing better with it in place.
20 amp circuit would be ideal.
DanDan
mantis wrote:Fix your electrical problem. Don't put a bad bandaid on it. The monster avs2000 in my opnion sucks ****. I have installed it many times and found nothing better with it in place.
Dan
Dan
I couldn't agree with you more on the fact that I need a 20 amp circuit, or anyone for that matter that runs separate amps as well as everthing else A/V on a single line.
And I haven't had any real first hand knowledge on using the AVS, except for the displays at the A/V stores.
From what I have seen, (taking it for what its worth), they had their conditioner hooked up to the stabilizer, with their 2 ch. and 3 ch. monster amp, and the stabilizer was keeping the voltage around 120 +/- 1 volt consistently.
With that said, I have been knows to buy crap I see at trade shows, and I think the only thing that I am still using is the Absorber, (fake chamois), now they are selling in every Kragen, Pep Boys etc.
All right, someone else that is using one please chime in. I can't base a decision on one bad review...
Scott -
I am already running two dedicated 20 amp breakers, one to the theater, and one to the 2 channel room.
Even so, doesn't current ebb and flow at different rates, which realisticly probably won't be noticed unless it's a big surge.
It sounds like a good thing, but don't know if it's really necessary.
High cool factor in looks though.
Others with opinions, let's hear 'em.
-Luc -
mantis wrote:The monster avs2000 in my opnion sucks ****.
Dan
Sorry Dan but I'll take the opinion of stereophile first. Plus, I own a 2000 and beyond the cool factor it DOES make a difference.
1/4twin***WAREMTAE*** -
I don't care for power conditioners. I realize it can help some rigs, but it's really only a less expensive band-aid on a bigger ac issue.
A true balanced power supply is where it's at.
Cheers,
I have experienced many different power sources. That said, I can't figure out what true balanced power actually means. Sounds like BLING ta me but I'm willing to listen.
