Signal Flow Direction?
124»
  • HiPerf360
    HiPerf360 Posts: 436
    edited December 2005
    steveinaz wrote:
    Giving electrons direction helps them find their way home. Come on folk's this ain't rocket science. :D
    Just a thought... Why don't we laser etch the arrow in the shielding wire itself before the insulation is applied, this way it will be easier for the electrons to see them. :p
    Sorry for all of the replies in a row... Just a little insomnia.
  • Skynut
    Skynut Posts: 2,967
    HiPerf360 wrote:
    my point of all this rambling is, well... look there is a squirrel!
    Exactly.
    A cute little squirrel.
    Skynut
    SOPA® Founder
    The system Almost there
    DVD Onkyo DV-SP802
    Sunfire Theater Grand II
    Sherbourn 7/2100
    Panamax 5510 power conditioner (for electronics)
    2 PSAudio UPC-200 power conditioners (for amps)
    Front L/R RT3000p (Bi-Wired)
    Center CS1000p (Bi-Wired) (under the television)
    Center RT2000p's (Bi-Wired) (on each side of the television)
    Sur FX1000
    SVS ultra plus 2
    www.ShadetreesMachineShop.com
    Thanks for looking
  • beardog03
    beardog03 Posts: 5,550
    poo nuggets..
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • HiPerf360
    edited January 2006
    Just couldnt let this end with "poo nuggets"
    But then again it might just be the perfect ending...
    END
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2006
    Poo Nuggets?...isn't that a new breakfast cereal?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • TroyD
    TroyD Posts: 13,124
    edited January 2006
    hee hee hee!
    She said POO-NUGGETS!
    BDT
    F1nut Posts: 51,962
    edited January 2006
    A picture is worth......
  • LiquidSound
    LiquidSound Posts: 1,261
    edited January 2006
    A thousand nuggets?
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
  • wingnut4772
    edited January 2006
    Ha! :D
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2006
    howie777 wrote:
    The arrow points to which end the shield is NOT connected to (or that is the common way to do it). The reason to only connect one end is to prevent noise that is picked up on the shield in the cable from reaching the amplifier. So in a situation where you have a DVD player connected to a receiver, you want the arrows pointing to the receiver. This way if any RF or other noise is picked up on the shield in the cables it is fed back into the DVD player and to the ground through the power cord and not into the reciever where it can couple onto the audio lines and distort the signal which then ends up coming out of your speakers. This makes perfect sense to me as I have been involved in a lot of EMC testing in my time as an enginner and this happens often in testing. Now if you have a DVD player that isn't designed well, you could end up with the same issue if the noise has the oppertunity to couple onto the audio lines where the DVD player is connected to the cable in which case you have not accomplished much. And the same if the receiver isn't designed well.
    So there you have it, a perfectly sound reason to use cables with shields and make sure they are connected properly. Mind you, if there is no noise coming into the system, it makes absoutly no difference, its just a precaution in case of unwanted noise. It shouldn't have anything to do with ground loop, if anything it would make it worse as you are extending the grounds not shortening them. If you don't believe me, well I don't care. I'm right and your wrong! (just kidding :D )
    As for burn in, I was told it is commonly refered to as skinning which only happends at very high frequency, as in Gigahertz. Which is well above any audio signal. I tend to believe more of the research that says you simply grow accustom to the sound of new spearker/wire over time and that sound becomes your center from which you judge all else on. So it sounds better because that is what you are expecting to hear. Besides, speakers/cables degrade with time, not get better. That just doesn't make any sense to me.
    I seldom post long quotes, but I thought this reply deserved a little recognition as it got zero above...
    Thing that gets me is that all audio devices step up the gain on the audio signal to some extent, so it seems that the place a given level of noise can do the most harm is where the signal strength is lowest. Howie, you mention design qulaity as a consideration, but what is inherent in an amp that makes design less of a consideration there?
    PS: Jesse, I think we've found your future avatar... :D
    __________________________
    Tour(Iused2beaChemE)2ma
    More later,
    Tour...
    Vox Copuli
    F1nut Posts: 51,962
    edited January 2006
    It's a gif, but it's not working....suppose to have poo nuggets dropping out.
  • Tour2ma
    edited January 2006
    I am really not sure how to feel about that malfunction...
    More later,
    Tour...
    Vox Copuli
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2006
    wrote:
    Feel free to email MIT with your point by point counter, to all that information above.
    Ugh, they won't answer my question about the y-axis % of their articulation response measurements. I'm thinking maybe its BS now. :mad:
    F1nut Posts: 51,962
    edited January 2006
