Signal Flow Direction?
fox
fox Posts: 62
edited January 2006 in Speakers
Not to appear overly stupid here, but I did get yesterday a better interconnect and speaker wire. Just one query here, when it comes to the interconnect between the CD player and preamp, in order to get it hooked up in the direction of the signal flow, wouldn't you connect it with the arrows pointing toward the receiver preamp and away from the CD player? The CD being your source and therefore the signal flowing from the CD player to the preamp? I tried it both ways and it works both directions, just want to have it hooked up the right way.
Thanks..
Post edited by fox on
«134
  • bobman1235
    bobman1235 Posts: 10,822
    edited December 2005
    Those arrows are nonsense.
    here's another thread on the same subject.
    VR3 Posts: 29,627
    they flow south... far far south!
  • BjornB17
    BjornB17 Posts: 752
    but if you are in the southern hemisphere they flow noth.
    KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
  • HBombToo
    HBombToo Posts: 5,256
    Thanks..
    You are correct Sir.
    ***WAREMTAE***
    F1nut Posts: 52,154
    That's an uninformed comment.
    "Most use the Bruce Brisson design (he designed Monster Cable, then MIT) With these, the shield is connected at the arrowhead end, and not at the arrowtail end. The arrowhead end should be at the preamp because for lowest hum, the preamp should be the only component grounded at the wall, and therefore, you want all currents from the shields to drain out through the preamp ground. This means that the IC connecting the preamp to the amp should also have its arrowhead pointed to the preamp -- so (even though it's counterintuitive) it really has nothing to do with direction of signal flow."
  • dorokusai
    dorokusai Posts: 25,576
    I agree.
    It's typically used to show the ground or drain wire for the shield and for some people, that's important, not nonsense.
    I've never heard or experienced a difference personally, but I'm not going to launch a crusade about it....it's an arrow, use it, BFD.
  • madmax
    madmax Posts: 12,434
    Is this true of the MIT's? It doesn't matter right now because I'm using an integrated but if so I've often had them hooked up wrong when using seperate amps.
    madmax
    Vinyl, the final frontier...
  • HBombToo
    madmax
    I agree with F1's approach and the primary benefit is the prevention of a ground loop. If there was a loop the additional shielding should help suppress the hum.
    HBomb
    ***WAREMTAE***
  • danger boy
    danger boy Posts: 15,722
    if you hook them up backwards.. with the arrow pointing in the wrong direction.. your music will play backwards.. with satanic messages hidden in the songs. LOL
    Where have i heard that before? Hmmmmmm????
    PolkFest 2012, who's going>?
  • LiquidSound
    LiquidSound Posts: 1,261
    The direction doesn't matter, neither do the types of cables you use. Actually, cables themselves are overrated. Since I stopped using them, I've had no ground loop problems, no hums..and my system sounds much more "airy". My speakers completely disappear sonically. It's a true night and day difference!!
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
    "If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
    F1nut Posts: 52,154
    Interesting point. I copied that from the other thread because it gave a good example of why cable direction matters, ie., grounding. However, I didn't notice the part about the pre amp/amp direction. I have always run the cables (direction of arrow) from the pre amp to the amp as it is stated in the MIT literature.
    "The arrows on the cable indicate the direction of signal flow- the network boxes go closest to the destination. (Reversing the direction will affect the sonic performance of the system!) Twin Terminator boxes are marked "Input" and "Output."
    Since the amp's power cord is grounded and there is no ground loop problem, I'll continue to do it the way they tell me.
    Somebody want to call Pete at MIT and ask him?
  • polkatese
    polkatese Posts: 6,767
    http://www.albinoblacksheep.com/flash/stairway.php
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
    heiney9 Posts: 25,582
    Unless you're in Australia, then they flow in the opposite direction...mate
  • WilliamM2
    WilliamM2 Posts: 4,809
    There is no direction for the signal flow, since it's AC and goes back and forth in BOTH directions.
  • BjornB17
    BjornB17 Posts: 752
    LOL look further up the page, and you'll realize that i made that joke already :cool:
  • HiPerf360
    HiPerf360 Posts: 436
    I think a lot of people don't understand this concept, or i have always been misled on the travel of electrons. I have always found there to be no audible difference between quality interconnects. In my experience as long as it has a good conductor and a well braided shielding layer you are good to go.
    And as far as speaker cable goes, the power going to your speakers is no different than the AC coming out of the wall (except frequency changes). As long as the wire is large enough for the current levels i've never heard a difference.
    Just my opinion though...
    Jonathon
  • BjornB17
    BjornB17 Posts: 752
    i just buy modestly priced cabled because they dont cost too much and look nice enough to not have to hide :)
  • HiPerf360
    I would have to agree with you on that point... must be a well manicured installation, and good cables routed correctly help that tremendously.
    F1nut Posts: 52,154
    It would be pc for me to say, "I don't know if you guys that can't tell a difference are the lucky ones or the unfortunate ones." However, I'm not pc, so I'm going to say you're the unfortunate ones.
  • HiPerf360
    It must be my years of sports car racing that has ruined my ears, but it seems to be affecting my eyes now too... i keep seeing all of these long time members that just want to start **** and not just respond with an intelligent response that can be backed up. If you want to be some professor of audio you cant just go around and insult people, try educating them on your view.
    Only the ignorant believe in something without asking questions.
    F1nut Posts: 52,154
    My, what thin skin we have. What part of, "I'm not pc", didn't you understand?
    If you'd like to do a search here, you'll find plenty of info by many of "these long time members" that have addressed this very topic, in detail, countless times.
  • HiPerf360
    Not thin skined...
    Backed up by fact or just the placebo effect?
    I am not a very pc person myself, but i do believe in the "golden rule".
  • TroyD
    TroyD Posts: 13,124
    Discounting F1's sunny disposition :D ...........
    I don't see any real differences in terms of substance on either side of the discussion. All anyone can offer in this particular debate is opinion.
    I hear a difference in wire/cables. As my gear has improved, I notice it more. If you don't, that's cool too.
    BDT
  • HiPerf360
    I agree hearing the difference in cables, these are just an item with a really bad diminishing return bell curve. I can hear the difference between "good" and "bad" interconnects, but the differences between a $50-100.00 cable compared to a $1000.00+ cable are inaudible.
  • TroyD
    TroyD Posts: 13,124
    HiPerf360 wrote:
    Not thin skined...
    Ok, for the sake of argument, why should we buy your argument that all wire sounds the same? Who says the burden of proof is on us to prove you wrong?
    BDT
  • TroyD
    TroyD Posts: 13,124
    I agree that wire/cables are a) insanely overpriced b) more susceptible to voodoo and BS c) in no small part due to a, b where the law of diminishing returns kicks in to high gear....
    However, you are offering your opinions as facts that would appear to require no corroboration. Regardless if I agree or not, your agrugment doesn't, inherently, hold any more water than an opposing view point.
    BDT
  • LiquidSound
    You people are so silly. My findings are SOLID!! Don't use cables and you notice an IMMEDIATE difference. Night and day people...
    Two Channel Main
    Receiver - VSX-54TX
    Mains - Csi40's
    F1nut Posts: 52,154
    HiPerf360 wrote:
    Not thin skined...
    Good, we'll get along just fine.
    If my ears tell me it's a fact, that's good enough for me. The real question is how does one prove to another that they can hear a difference. I mean, I believe you when you say you can't, but having heard the differences for myself I do feel sorry for those that can't as I really feel you're missing something.
    Do onto others as they would do to you. That one? Yeah, I believe in that, she was fun too. :D
    F1nut Posts: 52,154
    Maybe I'm not understanding you correctly, but first you say,
    And then say,
    I'm not trying to pick on you, but those comments seem to contradict themselves.
    Have you read the reviews in the Cable Swap Program? In there you will find one I did between $100.00 Nordost Solarwinds and $900.00 MIT S1's. Huge difference in sound quality, IMO.
  • fox
    fox Posts: 62
    Well, I think I have my answer now. Really did not mean to get a controversy started on this.
