LSI/FX vs. LSI7 for side surrounds
Foz
Foz Posts: 33
edited October 2005 in Speakers
Are the LSI/FX's worth the extra money over the LSI7 for side surrounds?
Thanks.
  • mantis
    mantis Posts: 17,694
    edited October 2005
    Not really but it depends on your room.
    If you sit close to the side walls then go with the Lsi/fx , if you have some room then I like the way direct rears sound. The Lsi7's all 4 in the rear is killer.
    Hell having another pair of Lsi7's as mains is killer 2 all hung on the wall.
    Dan
    Dan
  • McLoki
    McLoki Posts: 5,231
    edited October 2005
    I think the 7's sound improved dramatically when I mounted them with brackets to the wall rather than using the keyhole slot. (bass less boomy) I have 4 LSi7's and an LSiC right now and it sounds very very good.
    Michael
