Sony xplod box is done
KDC-MP5028- Kenwood deck
Phoenix Gold speaker wire
Alpine 6-1/2" Type-R Coaxial 2-Way Speakers- SPR17LP-, in side doors
Alpine 5x7" Type R speakers -SPR-574A-, in the back.
2 Alpine type R subwoofers in custom box
1000 watt Alpine -MRD-M1005- AMP
-Price invested- Over 1500$
Not the absolute best, but it works like a champ, you can hear it from like 2 or 3 blocks away from your stand point. -
I was shocked to find this while looking around, look at the #of$ this is,
http://rtgrim.com/store/xshs12.html
is it worth it?KDC-MP5028- Kenwood deck
ok, thanks for the pic, all i wanted to know was the ohm rating
ud want something 2 ohm stable like this:
http://www.crutchfield.com/S-wcw6eD18bH0/cgi-bin/ProdView.asp?g=100&I=489AP700M
its not overly expensive and comes highly reccomended by many a Club Polk member
Since its 2 ohm stable you just connect the positive terminal from the amp to BOTH of the positives on the speaker, same for the negative. Simple and effective. Picking ones nose signifies a strong sense of self discovery
System in the works:
PP 6V6 with 12ax7 pre ~ 20 watts
15" Jensen MOD 8ohm ~ 97db SPL
DiMarzio HS3 and/or Tone Zone S -
i doubt that price is right, they probably left out the decimal.. $7.11Picking ones nose signifies a strong sense of self discovery
.........sounds damn good, only thing, this is going to sound stupid and i know, but how in the hell am i suppose to change from 4ohm to 2ohm?hellohello wrote:ok, thanks for the pic, all i wanted to know was the ohm rating
Since its 2 ohm stable you just connect the positive terminal from the amp to BOTH of the positives on the speaker, same for the negative. Simple and effective.KDC-MP5028- Kenwood deck
its all in the wiring, when u wire it like i said, ull be using it in 2 ohm
i just realized that i use a lot of smileys...Picking ones nose signifies a strong sense of self discovery
s'okay, i use lots of ellipsi... see?...
SL - the coils are 4 ohm always, but the way you wire them (i.e. running from the positive lead of the amp to one positive of the sub, then from there to the other positive lead of the sub, so they're both hooked up - ditto negative) allows the amp to 'see' 2 ohms... and no, that $711 sony is way not worth it... i think they picked seven-eleven for a reason...
damn, i didnt see the 7-11 referece... i feel so blind :rolleyes:Picking ones nose signifies a strong sense of self discovery
I never realized a sub woofer fourm of all things could be this funny, wow thats greatKDC-MP5028- Kenwood deck
Because you guys are so good, do you think you could find info on a 1993 rockford fosgate sub, model # PCH-154, all i can find is the specs on it, i want to see what people have to say that have owned them...KDC-MP5028- Kenwood deck
i couldn't find any reviews (that's a 12 year old sub, that is), but from the specs, it seems to be average at best...It's not good, very fundamentally simply not good. - geolemon
hmm a 12 year old 15" sub... building another box are we?Picking ones nose signifies a strong sense of self discovery
hellohello wrote:hmm a 12 year old 15" sub... building another box are we?
It might happen, i dont know?KDC-MP5028- Kenwood deck
Wait a second, were you being a smart ****?KDC-MP5028- Kenwood deck
Still learning wrote:Wait a second, were you being a smart ****?
^always!
But if you already have the sub, mind as well build a box for it, u know, for practice
oh yea, its cool, i was thinking about it, but????? you knowKDC-MP5028- Kenwood deck
why waste the effort on an old woofer?Picking ones nose signifies a strong sense of self discovery
hey, if it still sounds okay, why not? if you have the time, patience, and materials to do it right, that is...It's not good, very fundamentally simply not good. - geolemon
^thats what im sayin! hey, even Jesus was a carpenter
hellohello wrote:why waste the effort on an old woofer?
Well, i could always swap the woofer out so.......but i have never had the woofer hooked up, it has never been used by any one!!!! it should be an experence.KDC-MP5028- Kenwood deck
oooo an unheard woofer.. dont expect too much if its never been used, probably still needs a break in, until the suspension and all gets nice and loose it isnt going to give its best performance, just like any athlete, it needs to "stretch out"
hellohello wrote:oooo an unheard woofer.. dont expect too much if its never been used, probably still needs a break in, until the suspension and all gets nice and loose it isnt going to give its best performance, just like any athlete, it needs to "stretch out"
True that, true that.KDC-MP5028- Kenwood deck
yyyyyepPicking ones nose signifies a strong sense of self discovery
any new progress on that 15"?Picking ones nose signifies a strong sense of self discovery
Nah, i have kind of skipping past that every day, if you know what i mean, plus the project im working on is a grand father clock right now........
There is bad news though, well at least for me, i was listining to that x-plod, out of the blues, it just cuts off???? WTF??? i replaced the fuse on the amp because it was toast, and still no sound from anything, the LED lights up for a second and then fades away???? damn it!!! is there such thing as a sub that just quits? with no signs? i mean this thing only has about 5 to 10 hours of music playing on it??KDC-MP5028- Kenwood deck
umm... sounds more like the amp than the sub, what kind of amp is it?Picking ones nose signifies a strong sense of self discovery
i asked that question because u may have run the amp at 2 ohms and it wasnt meant for it, that would blow the protection (fuse) and may cause damage to the amp's guts.Picking ones nose signifies a strong sense of self discovery
shouldn't have, the fuse is supposed to protect the guts... i'm assuming you've rechecked power and ground connections?It's not good, very fundamentally simply not good. - geolemon
