Subwoofer placement issue?
steve0202
I have moved to a new home and it seems like the only place for my subwoofer is about 3 feet in front of my right tower facing sideways (toward the receiver and left tower). I was told by someone that subwoofer placement is not an issue in most cases. Do you think the close proximity to the tower or the fact that it is pointed across my listening area will present a problem?
Rti70's
Csi30
PSW-250
RM5000 series II sats
Denon AV2802
Denon DVM 1815
Toshiba 32" TV/Monitor
Csi30
PSW-250
Denon AV2802
Denon DVM 1815
Post edited by steve0202 on
nope, especially if that's the only place for it
... no, the facing isn't a big deal, and if you have no other choice of location, that's that, isn't it...
if you have a couple places to choose from, this is an idea that seems valid - put the sub where you would sit to listen, then crawl around to your various possible placement locations and have a listen... pick the one that sounds the best...It's not good, very fundamentally simply not good. - geolemon
Is there anyway you can stick it a corner?RTi10
CSi5
RTi28
SVS PB12-ISD2
Denon 2106(pre/pro)
Adcom 5503(200x3)
Audioquest Diamondback ICS
Kimber Kable 8tc biwire(mains and center)
"Don't let your silly dreams fall in between the crack of the bed and the wall."
-J. James -
I would have to disagree.Placement of the sub is probably the most vital detail in getting strong and great sounding bass.steve0202 wrote:I was told by someone that subwoofer placement is not an issue in most cases.Panasonic 50" Plasma + Pioneer 6010
Toshiba XA2 HD-DVD
Panasonic BD30 Blu-Ray
Pioneer 1014
Polk RTi12 (front)...Polk CSi5 (center)
Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
3 Outlaw M-200 Amps -
I'm not an expert by any means but for me and everywhere I read placement can be a big issue. In my living room after trying 4 different locations finally it is in a good place and each place sounded differently.
......good luck and let us know how it works out.
Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
placement is an important but not as important as daily living, if the best sound is in the middle of a high trafic area, well you know what I'm trying to say.
