Subwoofer placement issue?
steve0202
steve0202 Posts: 28
I have moved to a new home and it seems like the only place for my subwoofer is about 3 feet in front of my right tower facing sideways (toward the receiver and left tower). I was told by someone that subwoofer placement is not an issue in most cases. Do you think the close proximity to the tower or the fact that it is pointed across my listening area will present a problem?
Rti70's
Csi30
PSW-250
RM5000 series II sats
Denon AV2802
Denon DVM 1815
Toshiba 32" TV/Monitor
Post edited by steve0202 on
  • neomagus00
    neomagus00 Posts: 3,899
    edited August 2005
    nope, especially if that's the only place for it :p... no, the facing isn't a big deal, and if you have no other choice of location, that's that, isn't it...
    if you have a couple places to choose from, this is an idea that seems valid - put the sub where you would sit to listen, then crawl around to your various possible placement locations and have a listen... pick the one that sounds the best...
  • nellis8166
    nellis8166 Posts: 292
    edited August 2005
    Is there anyway you can stick it a corner?
    RTi10
    CSi5
    RTi28
    SVS PB12-ISD2
    Denon 2106(pre/pro)
    Adcom 5503(200x3)
    Audioquest Diamondback ICS
    Kimber Kable 8tc biwire(mains and center)
    "Don't let your silly dreams fall in between the crack of the bed and the wall."
    -J. James
  • GaryZ06
    GaryZ06 Posts: 317
    edited August 2005
    I would have to disagree.Placement of the sub is probably the most vital detail in getting strong and great sounding bass.
    Panasonic 50" Plasma + Pioneer 6010
    Toshiba XA2 HD-DVD
    Panasonic BD30 Blu-Ray
    Pioneer 1014
    Polk RTi12 (front)...Polk CSi5 (center)
    Polk RTi4 (rear)...Velodyne DLS 5000-R Sub
    3 Outlaw M-200 Amps
  • PolknPepsi
    PolknPepsi Posts: 781
    edited August 2005
    I'm not an expert by any means but for me and everywhere I read placement can be a big issue. In my living room after trying 4 different locations finally it is in a good place and each place sounded differently.
    ......good luck and let us know how it works out. :)
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
  • Willow
    Willow Posts: 11,339
    edited August 2005
    placement is an important but not as important as daily living, if the best sound is in the middle of a high trafic area, well you know what I'm trying to say.
