low volume
UnderdogJay
UnderdogJay Posts: 5
edited May 2002 in Troubleshooting
Hello,
The problem I'm having is that I have to turn the volume on my receiver up to 20 out of 50 just to get a decent volume level out of my speakers and I don't think I should be having to turn it up nearly that high. I have a Sony STR DE975 receiver connected to Polk RT35i's as the fronts and a CS245i. I'm using 14 gauge speaker wire and I have checked all the connections to make sure everything is hooked up tightly and to the right terminals. If anybody could offer a solution or has an idea as to what the problem is please let me know. Thanks.
Underdog
Post edited by UnderdogJay on
  • mantis
    mantis Posts: 17,061
    edited May 2002
    Why worry about it,
    don't worry about the number,its just a number,forget about it.Enjoy your system.Is this the first digital volume control receiver you owned????Most people that come from a analog volume control express concern.
    Dan
  • gidrah
    gidrah Posts: 3,049
    edited May 2002
    The difference between 15dB&45dB is not as apparent the ddifference between 70dB&100dB. Don't be suprised, enjoy the music.
    Make it Funky! :)
  • mantis
    edited May 2002
    I did however fail to give one solution that could be a problem...sorry,
    Didi you calibrate your system with a SPL meter?If you don't own one I would suggest you buy one from radio shack.Its a great instrument for measuring the levels of each channel.It's hard to do my ear.This would be one of the only things I would worry about in your system.If your receiver does line level intinuation, check the preset level if it applies.Most receivers don't have this feature.
    Dan
  • UnderdogJay
    edited May 2002
    Thank you both for the advice. I think I just won't worry about it as long as it's no big deal.
