Home Theater setup...10.1
francis1967
francis1967 Posts: 161
Just wanted to say that this rocks!!
Anyone else doing something like this?
Noticing any comb effect or crosstalk?
[IMG][/img]HTsetup.gif
Post edited by francis1967 on
  • beardog03
    beardog03 Posts: 5,550
    edited April 2005
    my set up is kinda like this...
    I don`t know how to make the cool pic....so you have to use you imagination..!!!
    goes like this;
    RT2000i......RT55i.......245c........RT55i.............RT2000i
    SVS PC ULTRA !
    RT35i..............................................................RT35i
    ^FXi30.....................................FXi30^
    I now have LSi9`s in between the 2000`s and 55`s, a LSiC unber the 245, and LSi7`s by the 35`s...
    Oh ya, I also have a pair of SDA 2b`s on the outside of each 2000..!!!For 2 ch of course....
    The LSi series are being hooked up to three Rotel 980`s, I`m just waiting for more I/C`s...so the LSi`s are just there looking good...for the moment...all of the RTi`s are in play..:D
    the sub is on the right not the left..this *thing* won`t let me move it..!!
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • beardog03
    edited April 2005
    The "goal" to me , is to put yourself "in" the movie..without extremely loud levels..
    I try to make everything powerful and full...at levels that you would normaly speak to someone in the same room...maybe a little louder..!!:D
    okay maybe more than a little , but "believable levels, not insanely loud...you get my point..!
    The sound is all around you, so when someone jacks a round into a .45 behind you in the movie...you will hear it behind you..
    and I have actually looked behind me to see if someone was actually back there..!!
    gotta love it..
    oh, and fronts are on A/B channels, so I have not noticed any cross talk... yet
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • mantis
    mantis Posts: 17,570
    edited April 2005
    As cool as that looks,
    Why not have higher quality speakers , wire and amps inplace of all those speakers?
    I think with proper setup , you can gain what your looking for without have to use multiple speakers for each channel.
    But thats just my opnion, rock on my man,
    Dan
    Dan
  • francis1967
    edited April 2005
    What do you mean when you say that the "fronts are on A/B channels"? Are you able to use your zone2 capabilities iin your receiver/integrated and how do you then calibrate the "b" setting since it is separate from the "A"?
    Reason I am asking is that I have two channels on my receiver that I am not using at all, but I would really like to do so. I am currently having to run one set of fronts using normal high level speaker outs, and the second set of fronts using the two dedicated preamp outs for L/R mains.
    I would really like to understand how I can use those two last channels in my 7ch receiver. It is currently a NAD T773 so I have plenty of power. I was thinking actually of hooking up the speaks in parallell since the 4ohm load wouldn't be too bad, but it would be even better if I could use the 6th and 7th channel for fronts as well during movies.
  • beardog03
    edited April 2005
    mantis ,
    besides the cool factor, I also have to justify to the wife why so many speaks...besides just being a freak...
    so far not working well..!!
    The 55`s seem to add the mid`s that the 2000`s lack...
    they blend very well
    The rest of it is because I can..!!
    francis1967 ,
    I will PM you later...
    I have a Yamaha RX-V795 AVR, it`s about 7yrs old and runnin strong..DD/DTS, and all the other options...although I only use the DD & DTS..
    On the front it has two buttons...speaker A and speaker B
    THe 55`s are on speaker A
    THe 2000`s are on Speaker B
    The center is of course on center channel
    the rears are on the rear chanels
    sub out for the SVS
    becuase I have two sets of speaks on the rear I run the two off an outboard Rotel...
    The AVR does not support 4 ohm , so I have to incorperate the Rotels for the 4 ohm speaks...they are waiting for more I/C`s to arrive before they can all be hooked up..
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    oh yea..
    did I mention I am a speaker FREAK..!!?
    I have about 13 pairs..:D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
  • beardog03
    edited April 2005
    francis1967,
    your pm box is full...
    here`s another just because..:D
    Parasound HCA-3500
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    :cool:
