1…201202203204205207»
    xschop Posts: 5,897
    The guys on Phoenix said to make 100% sure the trans cover was isolated electrically from chassis. I went to great travail here just to do that.
  • Gardenstater
    Gardenstater Posts: 4,983
    I guess they are recommending that to eliminate circulating currents/hum but at the expense of diminished high frequency EMI isolation. They are in opposition.
    A single point ground strap rather than the double would still minimize ground loops and if you later measured residual hum or ground related noise it could always be lifted.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    xschop Posts: 5,897
    Or, if I hear any artifact/s from current configuration, I can simply remove the two rubber gaskets so the rear cover is technically making circuit with the chassis?
  • Gardenstater
    I'm already in over my head here lol. But maybe the problem with that might be that you could get a potential path for residual magnetic flux in the transformer to drive circulating currents through the chassis?
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • skipshot12
    skipshot12 Posts: 2,167
    xschop…
    Did you do the WOPL build?
    My two clair bros 700’s were built by Perry from audiophoenix.
    xschop Posts: 5,897
    skipshot12 wrote: »
    xschop…
    Indeed, so I followed Joe's advice on these matters...
    I was about to give a GFA-555 the full XS treatment before the 400 magically showed up. B)
    xschop Posts: 5,897
    Couple small tweaks to go....
  • ptrooper
    ptrooper Posts: 800
    Very nice mate.Extremely impressed here <3
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
