The guys on Phoenix said to make 100% sure the trans cover was isolated electrically from chassis. I went to great travail here just to do that.Don't take experimental gene therapies from known eugenicists.
I guess they are recommending that to eliminate circulating currents/hum but at the expense of diminished high frequency EMI isolation. They are in opposition.
A single point ground strap rather than the double would still minimize ground loops and if you later measured residual hum or ground related noise it could always be lifted.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Or, if I hear any artifact/s from current configuration, I can simply remove the two rubber gaskets so the rear cover is technically making circuit with the chassis?Don't take experimental gene therapies from known eugenicists.
I'm already in over my head here lol. But maybe the problem with that might be that you could get a potential path for residual magnetic flux in the transformer to drive circulating currents through the chassis?George / NJ
iFi nano iDSD DAC
iPurifier3
xschop…
Did you do the WOPL build?
My two clair bros 700’s were built by Perry from audiophoenix. -
skipshot12 wrote: »xschop…
Indeed, so I followed Joe's advice on these matters...
I was about to give a GFA-555 the full XS treatment before the 400 magically showed up.
Don't take experimental gene therapies from known eugenicists. -
Couple small tweaks to go....
Very nice mate.Extremely impressed here
VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
