CRS+ RestoMod
1234568»
    billbillw Posts: 8,285
    Looking forward to the finished amp pics. Quite a lot of fine work here.
    xschop Posts: 5,837
    xschop Posts: 5,837
    Fly cutting the long thin covers caused to much heat and started to warp. Decided to put on large upright belt sander 120 grit and cleaned them up. Will finalize at 320 grit hand belt sander to contrast with the flycut faceplate...
    xschop Posts: 5,837
    240 wet sand....
    xschop Posts: 5,837
    Went with .218 drill thru and touch deeper countersink to give more case adjustment of stainless flat heads and add bling before final sand...
    xschop Posts: 5,837
    edited October 16
    Last piece of the puzzle...
    xschop Posts: 5,837
    Will tie it in with a chamfer to match the faceplate...
