CRS+ RestoMod
So where are you with this project ?
Building a high current amp in high heat is a challenge. Last 4 weekends been brutal here lol...
https://www.youtube.com/watch?v=lmgQS07VQck Don't take experimental gene therapies from known eugenicists. -
Really don't understand why Polk didn't remake the CRS when the Legend line came out.
They originally planned to do a CRS+ size and a floor stander about the size of the 1C. I don't know for sure why they didn't, but I suspect it had something to do with the angled baffle BS. -
Or it had something to do with the new owners not having a clue. "Just put out a bigger soundbar" mentality.
Just got an email. My boards are done after some tuning....
Decisions....Flat black or gloss black the tranny?
VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
You've always wanted a flat, black tranny.
I see that last stack you smoked hasn't worn off.
Careful, or PPS will show up to your door.Don't take experimental gene therapies from known eugenicists.
I like flat on the stacked steel and gloss on the smooth end covers.
Where do you buy black paint?
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »I like flat on the stacked steel and gloss on the smooth end covers.
Im with you on that one @SCompRacer,Anything that looks like it's painted by a 3year old with a brush is Mat.
Going flat black insides of TO covers...
Chem strip, 220 grit, scotchbrite, then polished with Mother's..
Landed the WOA LED rout-outs and did initial fly cut...
Got a small break at the shop. Final fine fly-cut finish. Going to add 45 deg chamfer and clean the sides up to match the billet 5Jrs next...VSAT88 approved...
Stopped for a bacon, egg, cheeze biscuit and coffee. Got a new one out....
Bout to crack out the Cardas Quad...
I mic'd the boards for a future all billet case build....
Carn mate, don't leave us hanging—chuck up the pics!
Fire it up, mate! I’m absolutely frothing to see this thing pumping.VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
Hold your stable mates. Im still working on the amp. I have no doubt this one could run a big sey of SDAs.Don't take experimental gene therapies from known eugenicists.
Early morning shop time. 75 deg beats 105 all day...
Set up and ran 1/32" chamfer on the billet faceplate. One of the top covers will get the matching flycut finish when the CNC mill is open next visit...
Started facing the billet transformer cover/s.
Making a spare since I had material...
Looking forward to the finished amp pics. Quite a lot of fine work here.
