Elac Adante AF-61 (took some diy to make perfect)
Merci pour vos retour, mais ces enceintes ont un grave exceptionnel si elles sont driver par de gros amplis mono comme mes Musical Fidelity. J'aimerai vraiment trouver une solution pour la partie médium.
Translation:Thank you for your feedback, but these speakers have an exceptional bass if they are driven by big mono amps like my Musical Fidelity. I would really like to find a solution for the midrange part.
Upgrade the crossovers? Shrug. Might not do anything though if it's the uneven frequency response that your ear is taking offense to.
Again, I noticed the same upper mid/lower treble forward sound with the AS-61, it's just how they're voiced, or something related to the material choice for the coaxial drive unit.
You could also implement Dirac Live into your setup and EQ them that way. Good luck. -
Merci Clipdat,
je vous rejoint sur les 2 points. Un Dirac Live pourrait être envisageable et je pense également que la membrane en alu sur le coaxial y est pour beaucoup. J'ai appelé la Maison du Haut-Parleur cette semaine pour leur exposer mon souci et la personne avec qui j'ai parlé avait déjà eu des échanges avec d'autres possesseurs d'Elac AF-61. Il m'a proposé de me faire un devis pour remplacer le coaxial pour 1 médium et 1 tweeter. L'avantage sur cette enceinte c'est qu'elle a un filtre dédié pour la partie médium aigu. -
Thank you Clipdat, I agree with you on the 2 points. A Dirac Live could be possible and I also think that the aluminum cone on the coaxial has a lot to do with it. I called the House of the Speaker this week to tell them about my concern and the person I spoke with had already had exchanges with other owners of Elac AF-61. He offered to give me a quote to replace the coaxial for 1 midrange and 1 tweeter. The advantage of this speaker is that it has a dedicated filter for the midrange treble.Merci Clipdat,
If possible where you are do a comparison with the Kef R7 Meta. One issue I see with the Adante is the concentric driver is mounted high in the speaker cabinet and places midrange and tweeter above the ear height for most people when they are sitting comfortably. Kef doesn't tend do that. Many of Andrew Jones' ideas come from when he worked at Kef.
Or just try tilting the Adante forward a bit so the concentric driver is angled down slightly. It's not unusual for a tweeter to be mounted high, but having the midrange and tweeter both mounted too high could be an issue. -
Bonjour Emlyn,
oui c'est une bonne idée de pencher l'enceinte vers l'avant, j'avais essayé de les pencher vers l'arrière mais cela avait plutôt augmenter le problème.
Je vous ferait un retour.
Merci et bonne journée. -
Translation:
Hello Emlyn,
yes it's a good idea to lean the speaker forward, I tried leaning them backwards but that rather increased the problem.
I will get back to you.
Thank you and good day. -
Translation:
Hello Emlyn,
Okay, thanks.
There were a few verbs in there that I am unfamiliar with because I never used them to pick up chicks in Montreal.
I wanted those Elac towers to sound good, they sure looked good, but alas it was part of the journey. Tom, Trey and others were very polite with me back then not to say they sounded so off. Andrew Jones smh
Not gonna lie, wasn't a fan 😁😁😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
They probably just need to be tilted downward and have the polarity reversed.
We tried a few things and outside of just not sounding very musical there was a prominent delay between the mids and lows I couldn't overlook.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Maybe you just need to try his latest creation instead: https://jonesandcerreta.com/speakers/
Just wait a few years. They will sell for 50% asking.
Bro this is 3026, im listing them for more than new and I know what I have in my feelings, ok?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
