Polk Audio CRS + (RDO198) Crossover Modification Thread
    VR3 Posts: 29,763
    man you have some nice cylinders!!!
    Tony M Posts: 12,038
    They're exhibitionists too. :)
  • honestaquarian
    honestaquarian Posts: 3,287
    Oy such naked pawrts!😲😬
    VR3 Posts: 29,763
    Looks great!
  • honestaquarian
    He's got a Sunfire!!!! B)
    High Fives all the way around Sean o:)
    Kinda makes me miss my CRS's.
    Just a quick suggestion. Move them a little further apart. About a foot should do nicely.
  • Unknown
    edited April 2019
  • honestaquarian
    @ptrooper You have the same Sunfire Cinema grand Signature that I have. When I installed Trey's crossovers in my 3.1's and the impedance dropped, the Sunfire didn't even blink. 810 wpc I believe into 4 ohms yes?
    I cannot recommend using both the "Voltage" and "Current" outputs if your speakers are now bi-wire capable. "Voltage on the low end and "Current" on the high end.
    Btw according to research being able to hear proper stereo depends on the speakers being at least three feet apart.
    pitdogg2 Posts: 27,921
    I believe that was in fact recommended by Sunfire.
  • honestaquarian
    @ptrooper @pitdogg2 My apologies as I didn't complete that sentence and that thought.
    What I meant to say was that I cannot recommend using the "Voltage" and "Current" outputs if your speakers are now bi-wire capable highly enough!!!
    I am doing it with my 3.1's and have been all along even before the upgrades were done.
    Got to proofread before I hit post comment!!
    I definitely also recommend doing a serious upgrade to your MIT cables.
    I have the MH-750+ cables and I upgraded to the Shotgun S1's and S3's.
    I heard an improvement.
    Then I got another pair of S1's and heard an improvement when I swapped them out for the S3's
  • cortico
    cortico Posts: 593
    edited April 2019
    great job guys @vr3 @ptrooper per, I became a big fan of Claritcap... I wonder how the CMR compare to the CSA.
    VR3 Posts: 29,763
    Csa is no where close to the cmr, imo. The csa is a great cap but the cmr/Mr line is simply incredible, imo. Incredibly transparent
  • cortico
    cortico Posts: 593
    VR3 wrote: »
    Thanks, I need to try the CMR.
    cortico wrote: »
    VR3 wrote: »
    You'll need lots of space they're yuuuge
    Lol
    I wish i had the coin to try, I've heard no one say they were disappointed with them.
  • cortico
    cortico Posts: 593
    edited April 2019
    I see the pretty hefty price tag as well, $80 for the 6.8uf 400v rate. The CSA which is one bracket below costs $10... I can only imagine that the top of the line has to be much superior
  • Unknown
    edited April 2019
    cortico wrote: »
    Yea too bad they didn't make a 200v version. I'm sure that wouldn't bring the price down much, but they would be much smaller.
    VR3 Posts: 29,763
    Actually, the copper connect is most effective on larger caps. The copper connect is the copper lattice tied to the lead. Just a fwiw, that's why you won't find some smaller. Values below 620v
    VR3 Posts: 29,763
    I don't get to do to many of the crs but I looking forward to trying these with the 2b!
  • JayMX
    JayMX Posts: 464
    They’re almost too pretty to be hidden away… 🥲
    Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩
    Pairs that have passed through: Monitor 4b (Peerless), Monitor 5a (Peerless), Monitor 5B (Peerless), Monitor 5b (SL1000), Monitor 5b (SL2000) (4x pair), Monitor 7b (Peerless), Modified Monitor 7c’s (194’s), Monitor 10a (Peerless), Monitor 10b (5x pair), RTA8, RTA8TL, RTA 11T, RTA12c (194's), SDA1(mod to “a” & SL1000 Wuhan mod), SDA CRS, SDA 2 (2x pair), SDA 2a, SDA 2b, SDA 1b, SDA 1c, SDA SRS 2 (2x pair), SDA SRS 3.1TL (198’s) (2x pair)...and more to come, it’s a sickness.
    VR3 Posts: 29,763
    Here is the 2btl version!
  • Unknown
    xschop Posts: 5,932
    edited August 28
    Just copy my CRS+ dowel diagram B) Shakin' over here boss.
    You should copy the back-chambered RDO's too.
    You should also copy @Gardenstater's foam frame mod as well. Get the shout out.
  • Unknown
    xschop Posts: 5,932
    Foreigner just came out with a new album.
    Agent Pontificateur.
  • Unknown
