Polk Audio CRS + (RDO198) Crossover Modification Thread
I thought the factory enclosures could possibly benefit from a front to back cross-brace. Will you reinforce the area you cut out?
Looks great.
Sorry xschop for the late reply as I didn't notice this message 8 years ago
, sda 's would definitely benefit from front-rear bracing.I didn't reinforce this cut out but the front and rear baffles won't resonate at the same frequency, thats for sure.
These could do with your internal front to rear baffle brace and the Shaaaaken test
SDA SRS 1.2TL VR3 Duelund Monoliths<3,Lumin u2x,LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb...Working on it! -
Just copy my CRS+ dowel diagram
Shakin' over here boss.
You should copy the back-chambered RDO's too.
You should also copy @Gardenstater's foam frame mod as well. Get the shout out.Don't take experimental gene therapies from known eugenicists. -
Too right on the upgrade speaker basket reflections , but truth be told, those chambered RDOs are giving me the screaming abdabs,fair dinkum, it’s a bit hairy!
I learned a big word.....pontification----translates to ......On your soapbox!SDA SRS 1.2TL VR3 Duelund Monoliths<3,Lumin u2x,LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb...Working on it! -
Foreigner just came out with a new album.
Agent Pontificateur.Don't take experimental gene therapies from known eugenicists. -
Too right, mate! Love a bit of Foreigner. Head Games is an absolute ripper, Urgent goes off, and Cold as Ice is a bloody cracker of a trackSDA SRS 1.2TL VR3 Duelund Monoliths<3,Lumin u2x,LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb...Working on it!
