Rti100 - sub is dead
doggie750
doggie750 Posts: 1,171
edited August 9 in Troubleshooting
Likely an amp replacement unless I can fix this by replacing a cap? The power light is on. I enjoy using it in 2ch listening (pure direct mode)
Option 1: Fix it ..DIY
Option 2: Replace the towers
Please advise.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
    treitz3 Posts: 20,301
    What color is the power light?
  • doggie750
    It’s green
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
    Okay, swap the left speaker with the right speaker and test it again hooked up and playing. Did the issue follow the speaker, or is the other one not working now?
    This is done to isolate whether it is a speaker or an upstream issue.
  • doggie750
    Yep, did all the swapping. Confirmed it’s 1 speaker and I have a feeling it’s the amp plate need fixing.
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
    If the LED is green, the plate amp isn't showing any fault that I know of. Have you opened it up and confirmed that the connections inside the speaker didn't wiggle themself loose, creating an open in the circuit?
