Rti100 - sub is dead
doggie750
Likely an amp replacement unless I can fix this by replacing a cap? The power light is on. I enjoy using it in 2ch listening (pure direct mode)
Option 1: Fix it ..DIY
Option 2: Replace the towers
Please advise.
Please advise.
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
What color is the power light?
It’s greenGodspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
Odyclub; Xsimulator; Sony; Zune; Canon -
Okay, swap the left speaker with the right speaker and test it again hooked up and playing. Did the issue follow the speaker, or is the other one not working now?
This is done to isolate whether it is a speaker or an upstream issue.
Yep, did all the swapping. Confirmed it’s 1 speaker and I have a feeling it’s the amp plate need fixing.Godspeed,
D0661E
Surrounds: RTis
Sub:SVS PB12-Plus/2
If the LED is green, the plate amp isn't showing any fault that I know of. Have you opened it up and confirmed that the connections inside the speaker didn't wiggle themself loose, creating an open in the circuit?
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
