Billet RD-0194/8 Tweeter Bezels
12346»
    xschop Posts: 5,838
    6 left.
    xschop Posts: 5,838
    Made 6 extra alloys plates this weekend.
    So 12 left
    xschop Posts: 5,838
    10 available.
    xschop Posts: 5,838
    8 to go.
    PSA:
    Dont forget to use a piece of electrical tape over coil leads before installing with 4 factory magnet screws...
    and post pics when done.
    xschop Posts: 5,838
    Down to 4
    xschop Posts: 5,838
    All out. Where's all the install pics people?
    VR3 Posts: 29,752
    I asked Ai to provide a me a picture for you and it did not dissapoint
    Tony M Posts: 12,018
    edited June 29
    I've had other projects going on.
    Tools were everywhere on the floor. Kind of congested.
    I put in a new transmission in my Toro recycler personal pace mower, and it is DEFECTIVE. :s I told them about it, and they said to return it free of charge for review. I ordered another one, and it is arriving today. :) I hope I don't feel a momentary stoppage point like I did with the other one. It was a soft stoppage, so I thought the 190cc motor would overcome it, but it didn't. It SUCKED. The left tire would propel, but that was it. I took the geared wheel off and put a free-rolling wheel on, and the mower was 90% or more better, almost like new. I could pull it back EASY. The new trans wouldn't let the left tire roll back or turn at a different rate than the right.
    I also had my F150 4-shocks replacement project underway. That entailed one missing the bushings and a replacement shock waiting period for a few days too.
    When this is done, or not, I should be replacing those bezels soon.
    I have to check on my NAD C370 or (372?) int. amp, Newform speakers, and the wires connected to them on the speaker B connection. My Polk SDA-SRS2s are on speaker A, and they work fine. B) They're still AWESOME sounding! <3
    I heard a crackling sound from the Left Newform speaker a few months ago. The Bass cut out then. Then later, the sound cut out completely on the left. I'll check that out at the same time. :)
    xschop Posts: 5,838
    Tony M wrote: »
    Ok. You're excused. :D
  • dorokusai
    dorokusai Posts: 25,658
    Very nice indeed.
  • ptrooper
    ptrooper Posts: 739
    These Bezels are just so good,Anyone doing any upgrades on their SDA's needs to put this at the top of the list <3 !
    VR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable, <3 ,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it!
  • JCL
    JCL Posts: 174
    Finally got around to installing these plates in the 2.3’s. Originally thought it was going to be a pain to do. It’s actually very easy to replace the plates on the tweeters.1vtdy093xava.jpeg
    L600 (front), R200 (rear), R200 (rear surround), L400 (center), Sunfire HRS-10 (2)Marantz AV7706Sunfire Cinema Grand, Marantz M8077, Music Hall Stealth, Ortofon bronze cartridge, Parasound Zphono XRM, Sony UBP-X800
    SCompRacer Posts: 9,399
    7C's looking xschop sharp.
    xschop Posts: 5,838
    Great job. Enjoying the pics. I still prefer the Silverface look on the stock cabinets.
