1…199200202204205…207
  • jdjohn
    jdjohn Posts: 3,447
    edited July 23
    I picked-up a new-to-me line-level tube preamp last weekend. It is a Blue Circle BC3. I believe these came out near the 'turn of the century', if I can use that phrase at this point. I bought it from a local dude off FB marketplace. We had a nice conversation during the sale/hand-off, albeit in the boiling TN sun. These are two-piece units, with a separate umbilical power supply.
    The chassis turned out to be much larger (and heavier) than I thought from the pics, but that's fine with me. It is a true dual-mono design, with separate left/right volume knobs, input selectors, and tape monitor switches...and that's it on the front panel. The knobs are wooden, and quite substantial, with basically BBs, or small ball bearings, embedded in the wood as indicators. The chassis is all stainless steel, which contributes to the overall weight. There is a concentric blue light circle in the middle of the faceplate to indicate power is on. Honestly, the aesthetics don't appeal to me. I like simple, but I also like understated, and those knobs are definitely not understated. I will say they are easy to grab.
    The rear panel has a different layout as well. Left/Right input pairs (there are 5) and output pairs (there are 2) are spread-out on their respective sides of the panel, so not even close to being side-by-side. I also discovered that the RCA jacks are very slightly smaller in diameter than typical, so locking RCA plugs are almost a must, or plugs that are considered notoriously tight on 'regular' RCA jacks.
    Under the hood, there is point-to-point wiring, with most components glued to a blue acrylic board - blue, get it? There are only two tubes, which in the case of this unit, are JJ ECC99. Stock BC3 units came with 6922 tubes, but the seller of this unit sent it to Jena Labs in Oregon for 'upgrades'. I don't know enough about tubes to say whether the ECC99 configuration is an upgrade over 6922. Since I believe the ECC99 is exclusive to JJ, I guess I'm kind of stuck - no tube rolling. I took one of the tube fins and dampers off for these pics.
    The volume attenuators are a different (or less-common) design as well, being resistor-based stepped attenuators. It had to be a lot of work to build those!
    Finally, the caps in the signal path are apparently old-school military spec caps...based on my research. I think they are metallized film caps that are hermetically sealed - probably very reliable, but not sure about audio quality. It probably depends on the desired sound.
    I'm not very experienced with tube gear, but I do really like the sound of this preamp. I don't think it's super-duper tubey, but it definitely adds some of that holographic sound. It is very quiet, and does not introduce any tube hiss noise floor, which would frankly be a deal-killer for me. The bass is really impressive with this preamp. In fact, having my SVS powered sub connected to the second pair of outputs, I actually had to turn down the volume control on the SVS sub. Also, the gain attenuation is not very precise; so much so, that even at the first volume level setting, it is almost beyond low-level, background listening. "Sorry, honey...that's as low as it goes." o:)
    Overall, I'm very happy with this purchase. I'm not a fan of an overly warm sound, but this unit doesn't go too far in that regard.
  • Unknown
    edited July 23
    billbillw Posts: 8,339
    edited July 23
    A Blue Circle preamp! Nice. My brother used to be the US warranty service technician for founder Gilbert Yeung (Angela now). All their preamps and amps were custom made, point to point wired units with very high quality parts throughout. You got a gem there. Their phono preamp is also a gem with similar construction.
    My brother has been using BC components as long as I've been at this forum. My brother has always like the old Soviet military equivalent of the 6922, but I guess that's not an option with the change to ECC99.
    SCompRacer Posts: 9,404
    edited July 23
    I recall seeing those caps referred to in the antique radio forum. They were made by Sprague for JAN (Joint Army Navy for those who may not know). 56289 can be of various materials construction. Get a full M number and you can research that. I can see what looks like M83421?? / 01 on the top one and the extension 5270R on the bottom one but not positive. If so, "M83421/01-5270R is a metallized film/paper capacitor, specifically a 2.0 microfarad (μ F) 400-volt component with a 10% tolerance (R) built to MIL-PRF-83421."
    The stepped attenuators are very impressive.
    EDIT: If you were interested...
    https://landandmaritimeapps.dla.mil/programs/milspec/ListDocs.aspx?BasicDoc=MIL-PRF-83421
    Hey Jody,
    I messaged my brother and you have an earlier Mk1 BC3. It was known for the gain being high like you mentioned. The later Mk2 version included a Hi/Low gain toggle switch. My brother said you could modify the Mk1 to mimic the toggle found in the later unit. If you want, I can put you in touch with him.
    edited July 24
    The other quick fix for that is line level attenuators. They are offered in various dB drop, like 3dB, 6dB etc. The better ones use metal film 1% resistors. You can get them in RCA male/female or XLR m/f. I had a pair here for a DIY preamp from many years ago but cant put my hands on them. They were high end ones, came in a small lined box... lol
    EDIT: I was doing some reading about your new preamp. Like a ModWright SWL 9.0 preamp I once had, it inverts signal polarity requiring changing speaker cable polarity. The goal there is a single-gain stage circuit layout with nothing added to correct the reversed phase. IIRC reversing speaker polarity with those inverting phase preamps depends on how many gain stages your amp has. Worth looking into.
  • Butter
    Butter Posts: 66
    Just let the Raytheon heat up on and off the last couple of days. Thought I give em a listen. I’m pleased so far. Nice deep soundstage. Yet the instruments are much father forward. Nice deep tight bass as well.
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,394
    I believe those black resistors being used in the stepped attenuator are made by Holco (Holsworthy) and are well respected.
  • jdjohn
    jdjohn Posts: 3,447
    Thanks for the tips and advice on my BC3.
    Bill, I'll take you up on your offer to contact your brother. Always glad to have more info. I'll send you a PM.
    edited July 28
    I decided to just have one pair of speakers hooked to my 2ch rig. Probably time to kharma that four speaker selector switch. It made things easier for a few months, but I'm sure there was a loss in quality going through it.
  • Geoff4rfc
    Geoff4rfc Posts: 3,062
    Was able to upgrade my 2ch analogue path. Transport to DAC, DAC to Processor.
    Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB820-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-SVS SB5000-11.3
    VR3 Posts: 29,755
    Anddd...??? It sounded like.... 😬😬😬😬👀👀👀👀
  • Geoff4rfc
    VR3 wrote: »
    Lol, thanks for asking. I previously had a Mogami 110 ohm AES transport to DAC and AQ Yukons DAC to processor.
    I don't have any technical terms to describe what I'm hearing other than the signal has been cleaned up...a lot. There's more separation between the instruments, very crisp and clear. A worthy upgrade :)
    VR3 Posts: 29,755
    Awesome!
    edited July 31
    I finally finished putting together a system around kharma components.
    SDA-2B, thanks @vulcan
    Adcom 535ii, local FB sale for $150
    Kenwood KC-991, thanks @dorokusai
    Yamaha CDC-675, thanks to the pastor's wife who didn't want the old stuff anymore. (Also came with an RX-575 and some busted Klipsch that I semi fixed and gave away.
    Teac UD-301, my first real DAC from when I started streaming as my main source ~$250 back in 2017.
    Dell Optiplex 3000 thin client with Daphile. $42 from eBay.
    It sounds way better than it should for the investment.
    This is probably also the first time I've heard these 2B with a proper placement in a smaller room. I wish I didn't have to share this with my theater. It only works when I move the sofa back to the left side wall (screen on the right). The bass is much deeper and tighter than I would have expected from two active 6.5" woofers. Matt really was really a genius.
    edited July 31
    I meant two 6.5” per cabinet. So four total. The more I listen to this, the more I am amazed. Tap on a clip to paste it in the text box.Welcome to Gboard clipboard, any text you copy will be saved here. These are embarrassing the PSB Stratus Gold, although the it's not a fair comparison since this room is a fraction of the size of the main floor listening area which has 18’ cathedral ceilings and open to half the house.
    That's better. Stripping down.
    edited August 1
    That's really kewl! My first SDA's were a pair of 2A's with the pedestal base.
    I had a set of 1C Studio about 18 years ago, but never had them setup properly and they were running off of an AV receiver. This is a much better experience.
  • Unknown
    edited August 1
    Maybe it's 2B's I was thinking about that some had and some didn't have a pedestal base.
    SCompRacer wrote: »
    Yeah, most 2Bs, like most 1Cs, had the wood tops and bottoms. Both my 2B and 1C are/were, the vinyl studios.
  • Butter
    Butter Posts: 66
    I’ve been letting the Raytheon’s heat up over the last week. Not sure where to begin. They are black and silent! Deep blackness. As for ceiling or headroom, it seems extremely open and free. The low end is firm and strong. Nice and tight without being booming or thumpy. Listening to Frank Zappa the Grand Wazoo
    It has incredible separation of all the instruments and percussion. A very live sound which I like. There is a percussion break, and there is great definition between all the drums cymbals and percussive instruments. Horn sections sound very distinct. They do a great job of representing the live sound of a horn section. Zappa’s guitar has a really live feel about it. It’s very articulate and clear but it really retains that 70s sound. The soundstage is pretty wide 👍
    But I moved 1B’s 8’ apart and tried 6” off the rear wall so that really blew away my 7’ 3” sweet spot! So far freaking awesome!
    Tube newbie. Crazy how 2 tubes can totally transform your sound! I really love this hobby. Although hobby isn’t really an accurate description.
    xschop Posts: 5,887
    Worked on the XS400 some today...
  • joecoulson
    joecoulson Posts: 4,983
    jdjohn wrote: »
    Beautiful new acquisition Jody!
  • joecoulson
    indyhawg wrote: »
    Upgraded to an Eversolo T-8 from the Auralic Mini. Matches up nicely with the Denefrips Pontus II.
    How do you like the interface on that T8?
    I have been eyeing those to replace the streaming side of my Auralic when the inevitable arrives
    treitz3 Posts: 20,365
    Hey, Joe. Nice to see you are still around.
  • joecoulson
    Heya Tom
    Still kickin here.
    Hope you are well
    Absolutely! It's a shame about Auralic (and their forum). They had some good folks over there.
