R2R dac vs. Delta Sigma type dac
1234568»
    heiney9 Posts: 25,711
    It arrived. The guy didn't tell me he owns Midwest Audio in Indiana. Jason Walker is who I've been dealing with.
    https://www.stereophile.com/content/welcome-midwest-audio
    SCompRacer Posts: 9,401
    edited June 27
    Roon has an excellent oversampling and DSD engine built in that I can mess around with, if I so choose.
    I've been converting everything to DSD with Roon for years. It will also do PCM. The CPU in your device determines how high a level you can convert to. Roon shows the processing speed at top of Signal Path. It shows the rate of processing the audio compared to the speed of playback.
    Here I am at 1.7 with DSD512. Anything below 1.2 and you can get dropouts or no sound at all. I had to upgrade my CPU in the old Sonore Server to do DSD512. The old Intel MB only allowed for up to an Intel Quad Core i7-2600. With the old i5 CPU, DSD256 was ~1.3, 1.4.
    My DAC converts native DSD to PCM for the R2R ladder but it has a one-bit DAC to play native DSD without conversion. With DAC's that convert DSD to PCM I always suggest folks try it both ways. That is try equivalent high-res PCM and DSD with conversion to PCM to hear what sounds best.
    I'm still running Sonore Server>USB to Singxer SU-6 DDC>I2S via HDMI>Gustard R26 DAC>XLR to ARC Ref 3.
    I have a Roon Nucleus One server. I haven't had a chance to really get into it yet. Thanks for the information. Once I get settled with the sound "as is", I will definitely be experimenting with the DSD engine and oversampling. I will be somewhat limited because of the constraints of the Nucleus One and its processing power.
    The NO only does USB.
    With these specs I feel the Cyan 2 is pretty future proof.
    PCM 44.1-1.536M (32bit)
    DSD 64-512X (DOP)
    DSD 64-1024X (Native)
    The Nucleus One I believe has a max DSD (DOP) of DSD256. I am just learning and figuring it all out at this point. I'm just a noob when it comes to this OS and DSD stuff.
  • HzTweaker
    HzTweaker Posts: 1,136
    heiney9 wrote: »
    Same here, I haven't even started messing with the over sample mode in the k13 yet. Anyone know what I should expect the sound to be like if I do switch the modes?
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
    edited July 10
    Ok, for those that think everything sounds the same or mostly similar enough to not detect differences. Especially those that think double blind testing is valid in audio; I encountered a scenario last few days that confirms to me that I can hear even the slightest differences with my gear, playing my familiar music, in my familiar listening position.
    Those last 3 points are critical as many double blind tests have a bunch of people in an unfamiliar setting, with unfamiliar gear in an unfamiliar listening position w/inadequate listening time.
    The past 2-3 days I have been giving the office rig a work out. I am now very familiar with the (NOS) FiiO Warmer r2r dac, as well as the Burson Vivid 6 op-amps in the Keces HA-171. Awhile back, maybe 10-12 days ago I flipped the switch on the dac to OS - over sampling to get an idea what that sounded like. I wasn't overly impressed initially and after one other listening session (in OS) I started using the main rig to demo the Holo Audio Cyan 2 r2r dac.
    Over the past 2-3 days I fired up the office rig and was listening to that exclusively. As I am listening, something seems off. The width of the soundstage has narrowed slightly, the space around instruments had shrunk and the superbly "live" vocals and texture of vocals and acoustic music was just not there. Something had changed, something was missing.........
    More like 2.5D presentation than 3D. Even cymbals lacked the realism and decay I came to love about this dac. My first thought was to blame the JJ tubes, time to roll in the Amperex BB's apparently.
    Evening before last my computer restarted itself and last night I had a helluva time trying to sync Roon and the FiiO dac. After Google searching, one of the recommendations was to check to see if it was in OS mode. Windows and the USB driver fight each other (something about the sampling rate out of sync) I shrugged it off forgetting that I did indeed, a week and half ago, switch to OS mode for a demo.
    Finally, I checked all the connections and looked at the back of the Warmer r2r and it indeed was set to OS. All my listening up to this point has been NOS (non-oversampling). Meaning I had become intimately familiar with all the subtleties of much of my "go to" music. Those familiar subtleties were missing and my brain and my trained ear picked up on it. This is how I know "everything matters".
    After switching back to OS mode, the unit's synced up and the familiar sound points I was missing were back again. I really can't believe there is such a difference. Training ourselves to listen for certain things that make the experience rewarding and our brains interpreting these things are what it's all about.
    This experience (or experiment) cannot be relegated to a couple hour blind a/b/x test with unfamiliar methods and expect any sort of outcome than can be relied upon as evidence. It's take me months of listening to the same tracks to pick up and distinguish subtitles within my listening ritual that cannot be duplicated casually to determine an outcome. We all have our own set of expectations when we sit down to listen to various pieces of gear. There are certain attributes that are non-negotiable to me when I demo gear or upgrades, etc. But those attributes or expectations are different for all of us.
    It's not impossible to assume everything matters. Only if you know what to listen for, use your expectations, apply the attributes you find appealing about this hobby to every piece of gear that you get your ears on. This helps decide what's best for you, in your listening space, with your gear, with your ears and your expectations/non-negotiable attributes that make a listening session highly rewarding to you personally.
    Didn't expect to write this much, but I was thrilled to discover my "mistake" and now I'm a happy camper again. Once again proving "everything matters"
  • Conradicles
    Conradicles Posts: 6,434
    heiney9 wrote: »
    Well said. Great information H9. Got my 2nd R2R DAC on the way.
    audioluvr Posts: 6,079
    Well I broke down after reading all the comments from you all and ordered an Audalytic DR70 R2R DAC. Since the reviews were very positive and supposedly they are upgradable I figured what the hell. Out of the box it sounds like musical wallpaper. I'm currently running it 24/7 to burn in. If that doesn't change it's sound signature I'm never listening to you guys again.
    billbillw Posts: 8,320
    edited October 5
    If you don't like it, do they have a decent return policy? Sometimes you just need to go up a slight step or so to get to where the bliss starts. I personally don't like all in one boxes. A used version of the Denafrips Ares II would be a similar price, but without built in networking features. You'd have to have some type of streamer.
    VR3 Posts: 29,752
    Just remember that R2r doesn't do higher bit rates, so when you go over that threshold there is a secondary means of decoding present
    audioluvr wrote: »
    Give it some time. Geez, how long have you owned it? It usually takes me 4-6 weeks to evaluate a new piece of gear. Many times our initial impression doesn't stick for very long and may change a few times.
    Also, you're comparing a $349 piece against your high dollar Gustard. R2R only goes so far in a more budget oriented product.....just keep that in the back of your mind.
    edited October 5
    VR3 wrote: »
    Just running Tidal Master. Don't think that should be a problem. it's detecting 96Kbs same as the other one.
    Granted I'm comparing a $400 R2R to a $1,400 DS but from all the glowing reviews I figured it was worth a shot. I'll continue to let it burn in some more.
    edited October 5
    Make sure you audition in NOS mode, don't use the other filters just yet.
    heiney9 wrote: »
    That's the first thing I did when I did my initial setup.
    edited October 5
    All I can say it give it some time and really listen. Some of it is about the subtleties.
    Good luck, hope it works out in the end.
    Also, like Trey said, they really shine more and give the analog feel on 16/44 material. Going back and listening to well known CDs found low level detail that was glossed over with DS. Give it time.
    Well the verdict is out. R2R is lame (to me) Everyone's music tastes are unique. The Audalytic DR70 R2R DAC I purchased to demo is going back. I mean how much burning in does it need? It's been running 24/7 for 50 hours straight and though it sounds good, it reminds me of listening to a cassette tape on a Panasonic home stereo system. Granted that is as analog a sound as analog can get, it's just not for me. This may be why owners of the Gustard X26 Pro, II and III don't sell them. Even the guy who did a X26 vs R26 review said they were both superb. I'm not going to spend $1000 + for an R2R DAC just to hear the slight nuances of differences between them and what I have. I'm not THAT curious. Unless you have demo'd the Gustard X26's in your home on your system, you just don't know.
    edited October 7
    The system you have should be very well suited to an R2R dac. Perhaps this "particular" one wasn't for you. Hardly seemed up to the pedigree of the rest of your gear. Perhaps you'll give a higher end R2R dac a try some day.
    I have a lower end unit $399 retail and a higher end unit $1600.............they do sound markedly different. I use them in different rigs. Rigs that are appropriately matched for similar performance. However neither sound as you describe.
    IMHO, you hardly gave it any time (not break in) but listening time. Personally I could never fully evaluate any piece of gear in the short time you did.
    VR3 Posts: 29,752
    edited October 8
    What a bizarre test and comparison.
    I'm going to order the cheapest tube amp I can find to compare against my class ab amp and report on a few weeks how tube amps are terrible. It's the same thing?
    The power supply is arguably one of the most important aspects of gear and that alone can change everything.
    Be on the look out for a used abbas 2 series dac they pop up for around 800 or so time to time. One of the best dacs I've ever heard and I currently run the 2.4se
  • HzTweaker
    I'm still very happy with my Fiio K13 r2r dac compared to the DS the Pre is equipped with. AND I just got a "boat load" of new to me CDs to spin and listen to this fall/winter. :)
    The FiiO Warmer R2R dac has far exceeded my expectations. I've owned it quite awhile and didn't have the initial urge to roll tubes. To be fair I was tweaking another part of the system that is pretty well sorted out. It's time to start rolling.
    For me there are only 2 choices. They don't make it easy to roll the tubes. It's a delicate proposition and requires partial tear down.
    1) 1961 Amperex Bugle Boy 6DJ8 made in Heerlen Holland, large halo getter.
    2) 1971 Voskhod gray shield, single wire getter post, 6N23P. Reflektor made would be even better of the same vintage.
    I know there are others, E88CC, 6922, etc, etc. This is an office rig and part of the fun is getting stellar sound on a budget.
    Particular early 70's Russian 6N23P tubes are as good or better than the best Euro tubes. The ones I have are one step below the Holy Grail 6N23P. They cost about 1/2 to a 1/3 less than the Holy Grail 6N23P which are between $299-$399/pr.
    Nice thing is the Warmer uses 4 tubes, 2 for unbalanced and 2 for balanced. I only use the unbalanced outputs, so I only need (1) pair. The other pair (stock) is a place holder and need to be running to complete the circuit.
