CRS+ RestoMod
Got one double coated, dry, and test fitted. I may hunt down a rattle can with more antique hue for the PR covers...
After a few days curing, will go over them with 000 steel wool....
Don't take experimental gene therapies from known eugenicists. -
Looks great
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thanks Tre.Wife thinks so. She has better eye than I do. I'm glad I didn't drill the extra four spots on MW perimeters. Would throw off the retro look. They're growing on me.
I didn't make a billet baffle and didn't truck bedliner the cabs. There must be hope lol.
Still need to spin the terminals at a finer grit and find some 5/16" ring elec. terminals. My next shop visit will start the shorter XS Dreadnaught. Can't run the torroid out in the open, wire-nutted lmao.Don't take experimental gene therapies from known eugenicists. -
Tastefully done
Well, she did mention the 5Jrs complimented the kitchen appliances.
Indeed
Just awesome.
How tall are factory stands?Don't take experimental gene therapies from known eugenicists.
This factory stands quite tall, but its smokestack stands quite a bit taller.
Someone is smoking a stack.Don't take experimental gene therapies from known eugenicists.
The stock stands are in the 24" to 25" range...way too short! You want the tweeter at ear height (38" to 40") when seated.
I'm assuming those pucks at the top of the stand are half of the neodymium magnetic levitation devices for vibration isolation 👍George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Magnets? Just build a support bar at the top like the original stands. Use rubber pads between it and the cabinet.
No magnets. Those 2 spuds would go thru the bottom and compress the sand-filled tubes to their bases using long all-thread.
Will probably be a winter project.Don't take experimental gene therapies from known eugenicists. -
Probably why the 2B's sound great whether sitting or standing.
I Think 30" stands would be the sweet spot. That'll be the goal.Don't take experimental gene therapies from known eugenicists. -
Wow I like the way they are turning out. They look really good.
Nice work! Can't wait to see the stands.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Aawww. Rob I lovem. You’re always busy man. Check your junk mail 😛
lol. Hope you are well mate.
Yes and I’m
Your March 16 th post regarding the Ethernet network switch was very informative, I was so impressed with the Lumin u2 out the gate that I went for a LHY as6 to try with the sfp fibre optic kit , it’s a long trip from China and another week till it lands.
They say 300 hours for burn in for the Lumin and switch. I’ve done 145 hrs on the Lumin to date ❤️and the duelund monoliths love it !
I'm good. Busy here too. Glad to see the crocs didnt get ya. I sent a few PM long while back checking on you.
Between Fathers Day weekend, then Daughters Bday weekend, then car shopping weekend, I finally got to hear these in full blown SDA with the dreadnaught wire-nutted. I still need to get to the shop and build a shorter dreadnaught case.
I can see why some would consider these end-game Polks. If you know, you know...
For me, these tweeters are surely end-game Polk drivers.... I'll have to build another set for the 8TLs too.
Lil Update. Double bacon mod...
Nice to know you’re a bacon muncher. A tick in my bookVR3 SDA SRS 1.2TL Duelund Monoliths+VR31000va Dreadnaught +VR3 MM2 SDA cable,
,Lumin u2x ,<-sfp fibre <-LHYas8 Pro+ Switch,Transparent Reference MM2 xlr,power and speaker cables.FTA Sinope SE usb.40 Amp power line for amp with earth stake&Faraday shield ,20 Amp power line for digital equipment ->shunyata 8 venom power board...Working on it! -
Good job. I'm like that Beggin Strips dog with bacon. Go to breakfast, extra bacon, eight slices minimum. Get a burger, extra bacon. Hide the burger. I cook bacon outside on the grill. Lots of shrinkage and sampling. Take three pounds out come in with one.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Exquisite. Perfect. This is simply amazing…
I used to spend time on this forum and have a pair of CRS+ with internal mods from MSS/Dave that I just pulled out after many years in storage.
Listening to them has me BACK and now I’m totally inspired but lack the hands to even do a basic re-veneer.
I have the OEM stands and will give them to anyone who is doing a mod like this for free should they want to cut them down or use them.
So f cool.
https://www.youtube.com/watch?v=SECVGN4Bsgg
