My 12 step program has gone awry
    SCompRacer Posts: 9,235
    Here is an older thread from this forum discussing tube shields.
    https://forum.polkaudio.com/discussion/177718/tube-shields/p1
  • invalid
    invalid Posts: 1,555
    I really doubt that a power tube in a preamp is going to get near as hot as it would in a power amplifier output stage.
  • ALL212
    ALL212 Posts: 1,671
    What matters here is not how hot the tubes get but extending the life of, what are now expensive, tubes by removing what heat they do produce from the surface of the glass.
    I’d prefer to never have to purchase another tube. IERC covers may be the way to do so and if I can’t get those I’ll find others that are similar.
    Aaron
    Enabler Extraordinaire
  • ALL212
    ALL212 Posts: 1,671
    Emlyn wrote: »
    I found the Pearl Tube Coolers (not sure if that's the brand above) to deaden the sound on a preamp but didn't have a negative effect on the sound from a 6550 tubed power amp. They were inexpensive enough to try out, at Parts Connexion recommendation, and stash away if not being used.
    Yes, those are Pearls.
    I like IERC better - especially those with the internal “fingers” instead of plates.
    Aaron
  • Emlyn
    Emlyn Posts: 4,888
    Yes, Chris Johnson threw in a bunch for free to try out when I sent a Sonic Frontiers preamp in for upgrade. They were too much of a good thing on that 12 tube preamp but I did end up using some dampeners on the most important signal tubes to good effect.
  • ALL212
    ALL212 Posts: 1,671
    The “Lefty” is back in production. Lefty as it’s the left side of the listening room.
    Odyssey Audio Kismet stereo amp.
    Bottlehead Moreplay pre
    Bottlehead C4 headphone amp
    Twisted Pear DAC hiding in the repurposed Yamaha receiver chassis
    Nakamichi tape deck
    Polk LSi 7’s with massive upgrades
    Aaron
  • maxward
    maxward Posts: 1,736
    Cool dragon, too.
  • ALL212
    ALL212 Posts: 1,671
    edited January 11
    maxward wrote: »
    Cool dragon, too.
    Enhances the musicality by 5%
    He’s just shy of 50 years old.
    Aaron
  • maxward
    If he’s made of glass, he’s had a long lucky life. My wife collects dragons and plays around with glass.
    xschop Posts: 5,702
    Nice. I have one of those HP mini's with 1TB worth flac files. Great little Music server.
  • ALL212
    ALL212 Posts: 1,671
    That mini is one of a few Roon bridges in place.
    Aaron
  • ALL212
    ALL212 Posts: 1,671
    Did the gain reduction mod to give the volume pot some extra twist.
    Aaron
  • ALL212
    ALL212 Posts: 1,671
    And, you shouldn’t be surprised, but the R200’s (upgraded) completely smoke LSi 7’s (upgraded).
    7’s aren’t bad but 200’s are much better.
    Aaron
  • ALL212
    ALL212 Posts: 1,671
    The base is almost done. Three sides are a single piece of cherry. My BIL took it and built this. Had I done it we’d have had firewood. I’ve done the finishing. It’s just tung oil.
    Even the back (ran out of wood!) is nice.
    Aaron
    heiney9 Posts: 25,620
    Is there an upgrade thread for the R200's?
    msg Posts: 10,604
    edited May 28
    ALL212 wrote: »
    You are ded to me.
  • ALL212
    ALL212 Posts: 1,671
    Almost done. Just waiting for my Odyssey amp to return. Borrowed it to Klaus at AXPONA. Headphones work just fine.
    Aaron
  • ALL212
    ALL212 Posts: 1,671
    @msg I’m old - damn near ded anyway !
    Get that bike headed west!
    Aaron
    ALL212 wrote: »
    That wood case is beautiful!
    Nice job! Was that Cherry from the farm or the auction? I like the knobs too. You know you're getting old when it's RMD time. :D
  • ALL212
    ALL212 Posts: 1,671
    edited May 28
    This piece came from a sawyer we used years ago. He had a collection of bits he didn’t want and gave them to us. I think I took most of that. Some used in my cd shelving.
    Post edited by ALL212 on
    Aaron
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,999
    @ALL212, I'll have a drink in celebration of your fine work!
    Harry / Marietta GA
