My 12 step program has gone awry
ALL212
Must have clicked on something…
I guess as long as it’s here I might as well keep going.
Aaron
Enabler Extraordinaire
You're going to need more wood.
12 step programs are overrated. Can't wait to see the step by step build.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
You got that Bottlehead sale email too!
You get them kits quicker now they are located in IL.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
It’s the crack…."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
I’ve had enough crack.
This one’s the Moreplay.
Should I be concerned? This upgrade board is called out as the “claymore”
Aaron
Enabler Extraordinaire -
Be afraid, be very afraid...
Just avoid squeezing the M57 clacker, if included with kit.
I'm anxious to see an upgraded base.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
While pondering the plate color and base wood thought I’d start with the upgrade PCB.
Aaron
Is this the Bottlehead preamp with a 6v6 power tube?
Enough for today.
Not stock:
Power switch is a Cherry, not a big deal but the one that comes in the kit tends to melt if you leave heat on it too long.
Input terminals and the Goldpoint selector were pulled from a scrapped passive pre experiment that worked but provided no sonic improvements (and way less gain) then any other.
I’m going to try and stream in the upgrade kit rather than build stock and then rip/replace.
So far no additional cost but there are some upgrade caps on the way.
Aaron
I have the Foreplay II and to my ears and for the money. It is a great sounding tube preamp. Wish it had a remote control though.--Gary--
Next time you buy paint, check the expiration dates first.
Looks good! I was going to do my Otari faceplate and rack mounts with Rust-Oleum Textured Black. The face plate cleaned up nice, so I was just gonna do just the rack mounts. I shook the can really good, it started spraying then the feed tube clogged. I just used the Behr old rubbed bronze paint I had used for the head cover and returned the black for a refund.
Not my Otari deck, belongs to Nashou66 at AK, but this is what the textured black finish looks like.
Can’t say I’ve had that kind of paint problem…yet!
Power supply basics done. 330v DC where it should be. It’s just a bit high but I have no load at all on the transformer.
Aaron
Making progress.
A bit more but have to stop as I’m awaiting some caps.
So far voltage checks are good and I’ve yet to pick up the hot stick by the wrong end.
Aaron
What caps do you need? You bailed me out with some. If I can I will.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Got some 2.2uf 250v film caps coming down from Madison- should be here tomorrow latest.
Thanks fer the offer but I’ll wait it out. Best I do this slowly anywayAaron
Getting close…
Some checking to do yet and B+ wiring changes to accommodate the upgrade board.
Lose mogami wire there just to size up the paths needed. One output will be non amped for a straight to headphone amp connection.
Aaron
Huh.... how about that - it works! On the first try yet.
Aaron
Hey, nice work. Did you have to look at two sets of instructions to apply the update in the initial build?Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
AI was surely involved....
SCompRacer wrote: »Hey, nice work. Did you have to look at two sets of instructions to apply the update in the initial build?
Ya… Bottlehead doesn’t like you streaming in upgrades. Should it not work it will become very difficult for them to assist and I’ve seen them request the builder go back to stock.
I print (in color) both manuals and figure out what I can leave out in the basic build and where I need to go in the upgrade manual. I still got ahead in the basic build but in order to do volt checks sometimes you have to do basic and then back it out.
I picked up a 27” monitor in an auction. That helped a lot as I have it right at my work desk. I can blow up directions so the neighbors can read them!
One output is setup to go from selector straight out so I can run a headphone amp out of it.
Aaron
You and your tube fins, I like to see the fire in the bottle myself. It's like watching a bonfire 🔥🔥
Have never owned any tube equipment but me think's those heat sink fins are a good idea.
Does help in extending tube life via cooling?
Have also read about some folks damping the tubes for vibrations.
Do those fin things help with that too?
Looks cool.
Skip -
In theory - yes to both.
Extending the life of a 50,000 hour tube that I run for 100 hours a year might seem worthless but what the heck!Aaron
I would try without those things around the tubes, it will probably sound better.
I found the Pearl Tube Coolers (not sure if that's the brand above) to deaden the sound on a preamp but didn't have a negative effect on the sound from a 6550 tubed power amp. They were inexpensive enough to try out, at Parts Connexion recommendation, and stash away if not being used.
