SACD / CD Player
My Onkyo has bit the dust....which makes me sad since I just hooked it back up. Looking for a good, used player or transport that is considered "bullet proof" in terms of spinning and laser reliability. Also looking for good recommendations. Budgets is 1k which is a lot, but 850 much more doable. Thanks dudes.
    billbillw Posts: 8,346
    Are you planning to use a DAC with it or just straight from the analog outs?
  • kevhed72
    kevhed72 Posts: 5,243
    edited May 26
    billbillw wrote: »
    DAC is the plan. Key is it has to play SACDs also.
  • Unknown
    kevhed72 wrote: »
    billbillw wrote: »
    DAC is the plan.
    If you go for a DSD capable DAC, you might consider just ripping all your SACDs using a cheap bluray player and then you don't have to worry about another unit dying. For simplicity, I extracted the DSD files off all my SACDs about 7 years ago. Done once, and no worries about the laser going bad. There is no quality lost. You can play them from an SSD if you have a streamer than can read from local storage, or host them on a NAS which is nice, especially if you already have one.
    I had a post in the Going Digital sub-forum about a year ago with links to other sites that detail the process.
  • kevhed72
    Hard pass! Denon lasers were my two least dependable players. I won't even get into their customer service.
    Thank you sir..Here are some other options:
    Yamaha 2000
    Oppo 105
    Sony ES but these are getting old in the tooth
    Marantz DV series
  • kevhed72
    billbillw wrote: »
    kevhed72 wrote: »
    billbillw wrote: »
    DAC is the plan.
    While I appreciate this idea, I will never get around to ripping my SACDs to local storage or a laptop.
    I am too lazy lol.
    edited May 26
    At some point (we may already be there), there will be a severe shortage of good quality SACD players. Just saying.
    They are pretty rare, but maybe worth looking. I was really happy with the Pioneer Elite PD-D9j that I had before I ripped my SACDs. The build quality was better than anything I saw at the time under $1000. There is essentially no difference between the original and MkII version other than cosmetic. I compared the service manuals at one point.
    edited May 26
    Agree. Every Denon combo DVD/SACD player I've owned needed a laser replacement, even at less than 5 years old. I never touched the brand for disc players after the 3930 model I had needed two laser replacements (DIY) to start working. Even then, it was the most picky player I've ever owned. It didn't really like CD-R discs.
    EDIT: Actually, looking back at some of my thoughts when I had the 3930, it didn't have trouble with CD-R, it was the home burned videos on DVD-R that it didn't like. I did replace the laser and recall that being a headache.
  • Emlyn
    Emlyn Posts: 4,919
    The Oppo Blu Ray players I have had have been bullet proof, if there really is such a thing when it comes to physical disc players. The disc drives will fail eventually.
  • Conradicles
    Conradicles Posts: 6,435
    edited May 26
    I personally like the higher end Yamaha spinners.
    Nothing wrong with buying an older player and replacing the laser as it's usually pretty easy.
  • skipshot12
    skipshot12 Posts: 2,167
    Are you looking for newer or older?
    I have a couple I’d consider letting go.
    Skip
  • kevhed72
    edited May 29
    skipshot12 wrote: »
    Skip
    Either is fine.
  • skipshot12
    I have a couple disc spinners I’d part with.
    One’s the Marantz DV9600 and the other is a Pioneer DV-AX10.
    Also have a Marantz BD8002 that does everything including blu-ray but it does not play sacd.
    PM me if you may be interested.
    Skip
  • skrol
    skrol Posts: 3,497
    I have a few sitting around that are available.
    Denon DBP-1611UD BlueRay, DVD-V, DVD-A, SACD
    Pioneer Elite DV-45A DVD-V, DVD-A, SACD
    Sony DVP-NC80V SACD multi disc
    Oppo DV-980H DVD-V, DVD-A, SACD display is dim.
    I believe that I have remotes for all.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • skipshot12
    edited June 2
    Forgot to mention I have the original shipping box, manual & remote for the Marantz.
    I’m the only owner, bought it new through Marantz.
    The Pioneer I also have the original manual, remote and shipping box. I don’t have all the original innards for the pioneer’s shipping container though.
    I’m the 2nd owner of the DV-AX10.
    Purchased the Pioneer off the original owner on Audiogon many years ago.
    Both are in excellent condition, play and cosmetically, with a couple marks on the Pioneer.
    Skip
  • kevhed72
    skipshot12 wrote: »
    Skip
    PM sent
  • HzTweaker
    HzTweaker Posts: 1,136
    skipshot12 wrote: »
    Skip
    skrol wrote: »
    Obviously I'm on the back burner, but I might be interested in one of the players mentioned above. Please let me know if no deal is made. Thanks
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
  • skipshot12
    edited June 10
    Nothing yet Hz.
    Kevhed said he’s thinking about it.
    Which one are you thinking?
    The Pioneer is a beast.
    Have two of them.
    Have had my eye on the Marantz UD9004 but, they’re not in my price range.
    That’s the only one I’d replace my Pioneer with.
  • kevhed72
    Man that Pioneer is a beast after checking out some of the videos online. Ill decide here soon and update you Skip.
  • skipshot12
  • skipshot12
    Stereo phil reviewed that Pioneer when it came out.
    Check it out.
  • HzTweaker
    skipshot12 wrote: »
    Check it out.
    I will, thanks!
  • classic carl
    classic carl Posts: 689
    Still looking? I have a Marantz DV6001 that plays DVDs, CDs, and SACDs.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
    Teac R-919X ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • kevhed72
    edited August 16
    Well I purchased a Sony ES 9000 and promptly returned it to the EBay seller, and EBay promptly refunded my money in like 3 days when the seller did not immediately respond. Right now I have a very suitable Pioneer DV 79AVI which I am enjoying immensely and went on a SACD buying binge. You would think I would be content for now but I am still searching for my last SACD player ever with a replacement laser. More to come I guess…
  • Conradicles
    Good deal
  • Unknown
