SACD / CD Player
My Onkyo has bit the dust....which makes me sad since I just hooked it back up. Looking for a good, used player or transport that is considered "bullet proof" in terms of spinning and laser reliability. Also looking for good recommendations. Budgets is 1k which is a lot, but 850 much more doable. Thanks dudes.
Man o man I am a sucker for an open box deal - what yall think of this Denon?
https://www.safeandsoundhq.com/products/denon-dcd-1700ne-cd-sacd-player-with-advanced-al32-processing-plus-open-box?variant=52792315969903
Are you planning to use a DAC with it or just straight from the analog outs?See profile for rigs. Nothing else here.
DAC is the plan. Key is it has to play SACDs also.Are you planning to use a DAC with it or just straight from the analog outs?
Hard pass! Denon lasers were my two least dependable players. I won't even get into their customer service.
If you go for a DSD capable DAC, you might consider just ripping all your SACDs using a cheap bluray player and then you don't have to worry about another unit dying. For simplicity, I extracted the DSD files off all my SACDs about 7 years ago. Done once, and no worries about the laser going bad. There is no quality lost. You can play them from an SSD if you have a streamer than can read from local storage, or host them on a NAS which is nice, especially if you already have one.
I had a post in the Going Digital sub-forum about a year ago with links to other sites that detail the process.See profile for rigs. Nothing else here. -
Thank you sir..Here are some other options:
Yamaha 2000
Oppo 105
Sony ES but these are getting old in the tooth
Marantz DV series -
While I appreciate this idea, I will never get around to ripping my SACDs to local storage or a laptop.
I am too lazy lol. -
At some point (we may already be there), there will be a severe shortage of good quality SACD players. Just saying.
They are pretty rare, but maybe worth looking. I was really happy with the Pioneer Elite PD-D9j that I had before I ripped my SACDs. The build quality was better than anything I saw at the time under $1000. There is essentially no difference between the original and MkII version other than cosmetic. I compared the service manuals at one point.See profile for rigs. Nothing else here. -
Agree. Every Denon combo DVD/SACD player I've owned needed a laser replacement, even at less than 5 years old. I never touched the brand for disc players after the 3930 model I had needed two laser replacements (DIY) to start working. Even then, it was the most picky player I've ever owned. It didn't really like CD-R discs.
EDIT: Actually, looking back at some of my thoughts when I had the 3930, it didn't have trouble with CD-R, it was the home burned videos on DVD-R that it didn't like. I did replace the laser and recall that being a headache.See profile for rigs. Nothing else here. -
The Oppo Blu Ray players I have had have been bullet proof, if there really is such a thing when it comes to physical disc players. The disc drives will fail eventually.
I personally like the higher end Yamaha spinners.
Nothing wrong with buying an older player and replacing the laser as it's usually pretty easy. -
Are you looking for newer or older?
I have a couple I’d consider letting go.
Skip -
Either is fine.skipshot12 wrote: »Are you looking for newer or older?
Skip
I have a couple disc spinners I’d part with.
One’s the Marantz DV9600 and the other is a Pioneer DV-AX10.
Also have a Marantz BD8002 that does everything including blu-ray but it does not play sacd.
PM me if you may be interested.
Skip -
I have a few sitting around that are available.
Denon DBP-1611UD BlueRay, DVD-V, DVD-A, SACD
Pioneer Elite DV-45A DVD-V, DVD-A, SACD
Sony DVP-NC80V SACD multi disc
Oppo DV-980H DVD-V, DVD-A, SACD display is dim.
I believe that I have remotes for all.Stan
Main 2ch:
HT:
Other stuff:
Forgot to mention I have the original shipping box, manual & remote for the Marantz.
I’m the only owner, bought it new through Marantz.
The Pioneer I also have the original manual, remote and shipping box. I don’t have all the original innards for the pioneer’s shipping container though.
I’m the 2nd owner of the DV-AX10.
Purchased the Pioneer off the original owner on Audiogon many years ago.
Both are in excellent condition, play and cosmetically, with a couple marks on the Pioneer.
Skip -
PM sentskipshot12 wrote: »Forgot to mention I have the original shipping box, manual & remote for the Marantz.
Skip
skipshot12 wrote: »I have a couple disc spinners I’d part with.
SkipI have a few sitting around that are available.
Obviously I'm on the back burner, but I might be interested in one of the players mentioned above. Please let me know if no deal is made. Thanks
2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Nothing yet Hz.
Kevhed said he’s thinking about it.
Which one are you thinking?
The Pioneer is a beast.
Have two of them.
Have had my eye on the Marantz UD9004 but, they’re not in my price range.
That’s the only one I’d replace my Pioneer with. -
Man that Pioneer is a beast after checking out some of the videos online. Ill decide here soon and update you Skip.
Stereo phil reviewed that Pioneer when it came out.
Check it out. -
skipshot12 wrote: »Stereo phil reviewed that Pioneer when it came out.
Check it out.
I will, thanks!2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Still looking? I have a Marantz DV6001 that plays DVDs, CDs, and SACDs.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ (2x) Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2
Teac R-919X ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Winter Residence 2.1 (laptop system):
Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
Well I purchased a Sony ES 9000 and promptly returned it to the EBay seller, and EBay promptly refunded my money in like 3 days when the seller did not immediately respond. Right now I have a very suitable Pioneer DV 79AVI which I am enjoying immensely and went on a SACD buying binge. You would think I would be content for now but I am still searching for my last SACD player ever with a replacement laser. More to come I guess…
Good deal
Well, I guess, if you want a big changer.
Easy no for me.
25 years ago, maybe..
