CRS+ RestoMod
xschop
Again, big thanks to @dkfreebird for dropping these off. I've looked for ages for another set to build. I'll post everything that I do to these here. Will work on these over the summer. Thoroughly listened to them bone-stock last weekend. Goal is to get them sounding as dynamic as the SDA-converted RTA-8TLs, yet WAF friendly.
First question for the hive is what speaker grill cloth is best for sound transparency in white?
I'm going to strip and shoot the cabs white with all 100% machined brass parts and fasteners.
Thanks as always.
Already started the grill frame update...
Thanks as always.
Didn't even let the primer dry before snapping the pic...lol
That's a good primer.Political Correctness'.........defined
President of Club Polk -
Will test a satin vs. flat white paint....Honorable mention goes to KSM.Don't take experimental gene therapies from known eugenicists.
1.25" solid oak dowel
cross-cut 8 3/16" offset either side puts it angled and centered between front and back weak points...
This clears all drivers and factory crossover.
Reason why I cannot use the larger point to point board....
Power Grab time.
Don't take experimental gene therapies from known eugenicists. -
Something like this would still fit
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yes, the inductor fits where the old crossover fit- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You are definitely creative and meticulous. -
Very nice. I'll machine an adapter that mounts the Erse Super Q/factory X-over in factory location as well, mounting with 1 bolt. All other hardware will be machined solid brass, including the terminal plates, tweeter plates, and custom grill pegs.Don't take experimental gene therapies from known eugenicists.
Thanks for the kind words
really need to get the big sda inductor far away from the smaller ones for best performance- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Yet Polk put it directly behind the crossover board.
I’m not disagreeing with you.. -
I thought as long as they were in different orientations you'd be in the clear?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
Correct me if I'm wrong.
The big C-coil or laminated Erse are different critters than the original bobbin type Polk used behind the XO.
As far as the field they produce. -
Power Grab time.
What is the angle you cut this at? Definitely following along with your build.
Lol I'm far from the inductor police but pools handling of the large sda inductor was... Maybe not the best.
Mounted right behind the small inductors and mounted directly to aluminum on the big boys.
An inductor mounted directly to aluminum will decrease in value by over 10%- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good info!An inductor mounted directly to aluminum will decrease in value by over 10%
Grabber70Mach wrote: »1.25" solid oak dowel
Power Grab time.
On it's side view it is a parallelogram with each long side 8 and 3/16" long.
I started with a 8.5" length then gradually cut each end til it fit snug.Don't take experimental gene therapies from known eugenicists. -
I rasped on it this morning. (Pug Master need not comment) Rock solid now. This will translate to much improved midbass.Don't take experimental gene therapies from known eugenicists.
No need to denigrate these further other than the factory wiring terminals were ready to short and cause havoc....
Had a couple hours to work on them today.
Love that toasty vinyl smell. The front fascia was slightly peeling up around the drivers. Front baffle was actually congruent around perimeter although inset about 1/16". Filled seams with Gorilla Glue and driver recesses to aid in gasket sealing. Will shoot interior with rubberized paint.
I'll leave the rear fascia on until after I take an aggressive grit belt sander to rear edges....
I love that you’re doing this build. I mostly finished mine and have been absolutely loving them with your tweeter plates and the 198’s. You’re gonna be in heaven. I have been lax posting my build thread - will do it once I complete the Dreadnaught.
I must say, the @VR3 crossovers are amazing in build quality and sound quality and they mounted up great in the bottoms of my CRS+ cabinets. I used some 10/32 tapered head bolts with Aileen’s to seal from the outside and neoprene washers between the standoffs and the crossovers’ substrates to isolate and seal the cabinets further. Everything is cinched together and secured with nylock nuts. They’ll never vibrate loose and they’re airtight. I used the same method for mounting the inductors. The screw heads ARE visible, but they’re on the bottoms and backs of the cabinets…. So, you don’t see them unless you go looking. 🤷🏻♂️
I also built internal frame systems (glued in with liquid nails) which greatly stiffened the fronts and tops of the cabinets. They brace front to rear top to bottom. Only the back didn’t get a brace but it’s tough to do with the PR opening eating up most of the back of the cabinet. The frames also run lengthwise along the tops of the cabinets, each frame structure has four hurricane nuts installed so I can add some BH5 on 1/4” mdf plates behind the MW’s. I haven’t done this yet…. but one of these days I’ll get it done. Life has been busy lately. 😅
Needless to say these are the best speakers I’ve owned to date. Mindblowingly good on my Bryston 4B. Me love them long time. 😎
I flipped the crossover orientation after initial mockups to place the inductors as far away from the voicecoils as I could.
Your tweeter plates with Tre’s pads looking and sounding s e x y together!!
Veneeered the over the original oak cabinets with mahogany. Very happy with how they turned out. 🤩
Current Collection: Monitor 4a (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), Full mod SDA CRS 4.1TL (198’s), SDA SRS 2.3TL (198’s), R100's, R200’s, R300 🤩 -
We need a BADASS button
I will be doing every mod to date on these drivers. Think I will err on side of caution and add focus rings to all the MWs instead of electroplating their pole pieces with copper. I'll test run an electroplated MW6502 soon and see if it exhibits the same behavior as the focus rings.
I will also drill the MW pole pieces of 6510s and 6511's for an 1/8" punch to quickly try a different/shorter phase plug shape if I hear any anomoly.
The 198s are already done, focus rings and back-chambered. Will make brass bezels soon too...
Mesmerizing detail having just tested out in the XS-8TLs.
These drivers in this set are actually not as worn as many I have come across, so I'm hopeful.
I can also say that bone-stock, the factory inner curvature of the grill frames do help them "disappear" better.Don't take experimental gene therapies from known eugenicists. -
Nice Work!!!! Love It!!
That Polk and Bryston has to be a great match. I'm sitting here with some of those modifications myself.
With the Power Grab set, I'm able to pick up the enclosure by the dowel and it's taken up minimum cab volume....
Revising previous CRS+ Driver mod....
4ea needed.....
Collecting more solid brass parts...
Grill pins will be machined to dia. 0.430 full 0.9" length and glued to factory locations with 0.45" showing.
Think I've settled on the final aesthetic.
Matte brass drivers with antique white cabinets along with black oxide and matte brass fasteners for contrast...
Flat white is a second option, but satin white is too much...
I dig it
Go magnetic grills to really go all out 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are the factory Polk logos cast tin with brass color plating?Don't take experimental gene therapies from known eugenicists.
