House cleaning!
I will update this next week or so with more information but I am putting things out there for right now, life is very busy 0_0
1) Boxem A2408N amplifier -
ASR write up - https://www.audiosciencereview.com/forum/index.php?threads/boxem-audio-arthur-2408-n2-review-stereo-power-amplifier.18710/
Very good condition, no notable blemishes with original box
$400 shipped with paypal
2) Mark Levinson 360s DAC with PS Audio Radian right angle IEC
few marks here and there, overall in good cosmetic condition.
bottom feet are a little sticky
on power up unit shows code 8c14
missing metal cover inside unit
Normally goes for around $2000 to $2300
Despite the code, I can find nothing wrong with the unit and it sounds very good. I have used it with multiple inputs and both RCA and XLR outputs with no issues.
Asking $1500 shipped
3) Audiolund 1M Xtreme XLR cables
https://audiolund.com/product-category/xtreme-series/
$250 shipped
4) No Brand dual 12v linear power supply includes 2 x 12 v cables per PS (I think, Ill have to find them)
$90 shipped ea, 2 available. Will discount one $10 if both purchased
DC12V@ 3A
5) Epson EpiqVision Mini EF12 projector
good condition, used fairly regularly for about a year off and on. Will have it factory reset
Includes original box, remote, power supply + a longer power cable
$350 shipped
    VR3 Posts: 29,626
    Power supplies, found the 12v cables and will include an iec cable
    VR3 Posts: 29,626
    Boxem amp, includes original box manual etc
    Didn't notice any blemishes
    VR3 Posts: 29,626
    Audiolund xlr cables, very very nice quality
    VR3 Posts: 29,626
    Levinson dac and radiant power cable
    VR3 Posts: 29,626
    I'm open to offers
    I plan to list elsewhere end of next week
    If someone is local for the projector I'll throw in the 110" screen!
    mhardy6647 Posts: 35,372
    That danged Boxem is callin' to me with its little PWM voice... but...
    1) we no do paypal no mo'.
    (and more to the point)
    2) Mrs. H would kill me and sell my organs on AliExpress...
    :blush:
    VR3 Posts: 29,626
    edited February 17
    Send me a check
    I'll even knock off 4%
    VR3 wrote: »
    Send me a check
    You are a bad man...
    gonna test the waters with the little woman (ahem)... although I really have grown very attached to my viscera (or maybe vice versa). Perhaps I should hide the kitchen knives first...
    pitdogg2 Posts: 27,553
    You had better sharpen them all first! The last thing you need is an infected cut from a dull knife, A sharp cut heals faster especially at your age......
    What're you doin', Mark?
    Just sharpenin' knives! Why'd'ya ask?
    audioluvr Posts: 6,010
    VR3 wrote: »
    Send me a check
    Easier to ask for forgiveness then permission. DO IT!
    VR3 Posts: 29,626
    Bump, will list things this weekend on usam
  • HzTweaker
    HzTweaker Posts: 1,074
    Is there any way to open up the LPS and adjust the volts/amp output?
    Also I'm not familiar the connectors that attach the cables to the LPS, is there a- that connector plus USB-C option?
    VR3 Posts: 29,626
    I know you can order these in different voltages but I wouldnt be able to provide info on adjusting the voltage unfortunately. I am not aware of a USB C cable that will work for these either
    Sorry :(
  • HzTweaker
    Okay, Thanks.
    GLWTS
    billbillw Posts: 7,956
    HzTweaker wrote: »
    Linear Power Supplies are not designed to change voltages easily. The transformer has windings to give a certain voltage output from the given input, and the regulators are also designed to give a fixed voltage output.
    VR3 Posts: 29,626
    Bump for not having time to do anything elsewhere yet
    VR3 Posts: 29,626
    Update
    One 12v power supply sold
    Audiolund cables sold
    Price drop levinson dac 1250 shipped
    Boxem amp 375 shipped
  • kevhed72
    kevhed72 Posts: 5,187
    Sir
    Are you a proponent of separate DACs and dedicated streamers, or going the route of say an Eversolo DMP A8 or a HiFi Rose all in one solution?
    VR3 Posts: 29,626
    I definitely don't put my eggs in one basket.
    Dacs are timeless. Streamers will be paper weights in 5 years... Minimize cost there and focus more on dac performance.
    90% of the streamer performance is the power supply. I run a mini dsp sdh studio with a nice power supply and it sounds every bit as good as the 7k lumin u1 x it replaced.
    Trey, I think for a certain period of time in the last 15 years, it was the DACs that became paper weights in 5 years due to massive improvements year over year. I'm still using a DIY streamer that does everything I need it to and its based on a thin client PC that came out in 2018.
    I will agree that it is better to have a separate DAC and streamer.
    treitz3 Posts: 20,206
    I will always have separates in that department. You can change out one or the other if you want to change up the sound or introduce tubes, etc..
    An all in one is just that. You are limited in what it sounds like, with little changes.
    With separates, it opens up your options vastly. Yes, more cabling, which means more expense and real estate, but you aren't as limited if you want to change something else in the system that has a negative effect with your all in one unit. Having options is worth it to me.
    VR3 Posts: 29,626
    Dacs are extremely versatile components, I find the older ones are fantastic if you look in the right spots
    Toolfan66 Posts: 18,287
    edited May 16
    Edit: went to add something, copy and paste, wiped out what I posted, said F-IT I’m not retyping it.. 🤣
    Post edited by Toolfan66 on
