House cleaning!
VR3
I will update this next week or so with more information but I am putting things out there for right now, life is very busy 0_0
1) Boxem A2408N amplifier -
ASR write up - https://www.audiosciencereview.com/forum/index.php?threads/boxem-audio-arthur-2408-n2-review-stereo-power-amplifier.18710/
Very good condition, no notable blemishes with original box
$400 shipped with paypal
2) Mark Levinson 360s DAC with PS Audio Radian right angle IEC
few marks here and there, overall in good cosmetic condition.
bottom feet are a little sticky
on power up unit shows code 8c14
missing metal cover inside unit
Normally goes for around $2000 to $2300
Despite the code, I can find nothing wrong with the unit and it sounds very good. I have used it with multiple inputs and both RCA and XLR outputs with no issues.
Asking $1500 shipped
3) Audiolund 1M Xtreme XLR cables
https://audiolund.com/product-category/xtreme-series/
$250 shipped
4) No Brand dual 12v linear power supply includes 2 x 12 v cables per PS (I think, Ill have to find them)
$90 shipped ea, 2 available. Will discount one $10 if both purchased
DC12V@ 3A
5) Epson EpiqVision Mini EF12 projector
good condition, used fairly regularly for about a year off and on. Will have it factory reset
Includes original box, remote, power supply + a longer power cable
$350 shipped
$250 shipped
DC12V@ 3A
$350 shipped
Power supplies, found the 12v cables and will include an iec cable
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Boxem amp, includes original box manual etc
Didn't notice any blemishes
Audiolund xlr cables, very very nice quality
Levinson dac and radiant power cable
I'm open to offers
I plan to list elsewhere end of next week
If someone is local for the projector I'll throw in the 110" screen!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
That danged Boxem is callin' to me with its little PWM voice... but...
1) we no do paypal no mo'.
(and more to the point)
2) Mrs. H would kill me and sell my organs on AliExpress...
Send me a check
I'll even knock off 4%
😁 😁 😁- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Send me a check
You are a bad man...
gonna test the waters with the little woman (ahem)... although I really have grown very attached to my viscera (or maybe vice versa). Perhaps I should hide the kitchen knives first...
You had better sharpen them all first! The last thing you need is an infected cut from a dull knife, A sharp cut heals faster especially at your age......mhardy6647 wrote: »Perhaps I should hide the kitchen knives first...
What're you doin', Mark?
Just sharpenin' knives! Why'd'ya ask?
Easier to ask for forgiveness then permission. DO IT!Gustard X26 Pro DAC
Bump, will list things this weekend on usam- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Is there any way to open up the LPS and adjust the volts/amp output?
Also I'm not familiar the connectors that attach the cables to the LPS, is there a- that connector plus USB-C option?2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Standby: LSi9s with VR3's Fortress mods -
I know you can order these in different voltages but I wouldnt be able to provide info on adjusting the voltage unfortunately. I am not aware of a USB C cable that will work for these either
Sorry
Okay, Thanks.
GLWTS2ch rig: Speakers: Magnepan LRS w/Magna Riser stands Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
Linear Power Supplies are not designed to change voltages easily. The transformer has windings to give a certain voltage output from the given input, and the regulators are also designed to give a fixed voltage output. -
Bump for not having time to do anything elsewhere yet- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Update
One 12v power supply sold
Audiolund cables sold
Price drop levinson dac 1250 shipped
Boxem amp 375 shipped- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Sir
Are you a proponent of separate DACs and dedicated streamers, or going the route of say an Eversolo DMP A8 or a HiFi Rose all in one solution? -
I definitely don't put my eggs in one basket.
Dacs are timeless. Streamers will be paper weights in 5 years... Minimize cost there and focus more on dac performance.
90% of the streamer performance is the power supply. I run a mini dsp sdh studio with a nice power supply and it sounds every bit as good as the 7k lumin u1 x it replaced.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Trey, I think for a certain period of time in the last 15 years, it was the DACs that became paper weights in 5 years due to massive improvements year over year. I'm still using a DIY streamer that does everything I need it to and its based on a thin client PC that came out in 2018.
I will agree that it is better to have a separate DAC and streamer.
I will always have separates in that department. You can change out one or the other if you want to change up the sound or introduce tubes, etc..
An all in one is just that. You are limited in what it sounds like, with little changes.
With separates, it opens up your options vastly. Yes, more cabling, which means more expense and real estate, but you aren't as limited if you want to change something else in the system that has a negative effect with your all in one unit. Having options is worth it to me.
Dacs are extremely versatile components, I find the older ones are fantastic if you look in the right spots- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Edit: went to add something, copy and paste, wiped out what I posted, said F-IT I’m not retyping it.. 🤣Post edited by Toolfan66 on
Dac sold
Price drop on the boxem to 325 shipped- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
