Monster 14-4 vs Audioquest 14-4
mantis
Yeah Bored today, doing laundry , waiting on clothes to dry so I can swap over my laundry. It's been snowing all day long, I didn't even get a shower yet.
So I decided since I had my monster cable cables in my hand to just do a shootout as I have not done this in years.
Song I picked 2 to keep it simple and to pay attention to the details I know all so well.
Mike Dawes "Encomium
Kip Winger "How far will we go?"
I know these 2 songs as good as any other 2 so they made the list, they sound great and there is a lot of stuff to focus on to hear any differences in swapping out speaker cables.
I ran both songs on both cables all the way through, Then I focused on 1 minute of each song on each pair and tried to find any differences at all.
So the Audioquest cables I know exactly how they sound. They are clear as day, clean and do not restrict anything that I can hear. They are natural and beautiful sounding. I can't find a single thing about how they pass the sound to the speakers and handle the wattage that I can put my finger on that is faulty or bad. These are excellent cables , they are cheap as the day is long compared to some of my other cables that cost Hundreds more.
The Monstercables have a slightly different sound. Something is different and I'm having a hard time putting my finger on it. I think the volume dropped ever so slightly. It seems all the detail is still there, nothing seems to be missing. I can hear and feel the dynamic range of these 2 songs . I gotta swap back in the Audioquest to compare.
So back went in the audoquest cables and there is a slight volume up. I should have grabbed my SPL meter to confirm what I'm noticing. At 8 foot lengths of 14-4 copper wire speaker cables, there should be absolutely no difference in output. There is no restriction at this volume or at this length vs the gauge and wattage output I'm using. I was probably around 85-90 DB max with soft passages and loud dynamics.
Back went in the Monstercables and now I'm not noticing the volume differences but again something ever so slightly is different. What the hell is it???
Back goes in the Audioquest and I think I found it. It's the volume of things inside the sound. The finger picking, the thump on the guitar with Mike's song . On Kip's song, his voice , you can notice his breath more.
Back in the Monster and yup , that is what it was. There is just a small ever so slight difference in detail. The monster sits the finger noise, the breath and the thumps a tad back.
So now you have to wonder which cable is doing the original recording right or wrong? I have no idea which way is correct. I can say what I like better but as being accurate? No Idea.
I don't hate or dislike how the Monster cables sound. They have a pleasant sound to them that is nice and without the audioqest cables pointing out certain things, they are pretty nice sounding cables, if cables make sound LOL. It's the ability to transfer the sound is probably a better way to refer to this as. The Audioquest cables bring things a bit more forward instead of slightly laid back as the monster do.
Construction wise the Audioqest cables use more solid core conductors and less strands. Monster uses more fine conductors and rerverse wind them . If you were to ask me what's the difference. I think the difference lays in how these cables are constructed. Both use high quality copper, no idea who's is better. They both are the exact same gauge, both are bi wires , both are using their own Banana plugs. They are also both cold welded so there is no heat solder joints to worry about.
In the end of this time consuming fun little test, audioquest and monster have good quality cables with an ever so slight difference in how they present sound. Again I can't sit here and tell you who's is better. Both songs sounded great on both cables.
If this was a blind test, I think I would say I prefer A over B or I like the way B sounds relaxed and maybe A is aggressive in a small way. All the sounds are there neither cable missed anything. So with things like this , I think it's just what you like OR you figure out how to find out which cable is closer to presenting correctly and go that way if you prefer.
Dan
It could also be the different banana connectors, may be different metal or internal construction, having an impact on the sound.
Liked this comparison.
A big Monster fan here.
Have Monster’s ME2K and the 2.2s.
Really like the Sigma’s, my findings are that they’re a tad more laid back in the treble with a strong emphasis on bass.
If one has a very revieling system the Sigma’s can tame that top end of needed.
Also tried Monster’s Sigma Retro Gold’s.
They were way too relaxed of a speaker cable, almost to the point that they had too much of a difference on the top end freq’s.
Too laid back in my system that’s already a mellow sound.
They may have worked well with the Infinity Prelude MTS’s as they’re a very revieling speaker.
Never got the chance to try them on those. -
Audioquests banan plugs are made of High-purity Beryllium Copper. However the Monsters I think are gold plated Some kind of copper alloy mix. They very well could be brass, I don't remember.Dan
skipshot12 wrote: »Liked this comparison.
I have owned and tried out almost ever monster cable made. Analog , HDMI , Digital , speaker wires etc. Monster made pretty solidstuff back in the day meaning 90's -2000's. After that they started to change for the worse, things got strange and at that point we were deep into Audioquest. Moved on from Tributaries , monster , and Transparent.
At Bryn Mawr then Tweeter we use to have all kinds of wire shootouts. I use to like the MCX cables which where more affordable then the 2.2's but gave off some awesome sound quality.
I still have a lot of analog RCA cables in like new condition just chilling. I also have a few Coax digital cables as well.Dan
The single biggest problem with Monster ICs (especially the “higher end” ones) is the fact that they suffer from significant under-spec in their dimensions, which leads to ridiculously tight connections, and ultimately costly damage. I can’t tell you how many RCA jacks I have replaced for people over the years, due to the shields being pulled free of the gear with the interconnect cable. In every single case, it was Monster Cable. Every one. I know you can just jamb the shield back over the Jack and hope for the best, but to fix it correctly, you need a new RCA block that meets spec, and it needs to be soldered to the PCB.
I can’t tell you already hear folks saying “…you need to remove them gently, and “twist” as you pull them free…”. Yea, ok - OR, Monster could spec their ends correctly (like virtually every other cable manufacturer) so that this damage didn’t occur in the first place.“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
^Agree 100%.
They are very tight on the ME2K Sigma Interconnects.
If one's using those rca's interconnects I highly recommend upgrading the rca jack or that's exactly what happens.
Was running rca's to my Infinity Prelude MTS's, line level connection to the sub, and pulled the sleeve right off.
Good luck with the spinning technique with those interconnects.
Why on earth did they use such gorilla grip ends on those?
Have quite a few XLR balanced ME2K Sigma interconnects but, most of my gear is vintage now and don't have the capabilities.
They are wicked nice cables, can only use them if the Krell AVS is in the system. Then, it's only from the disc spinner to the Processor. Amp & preamp I'm out of luck. -
It's actually not an issue when you know how to use them. They are unlike anything on the market that I know of. The Turbine connectors were special. When we were Monstercable dealers , we got trained on all their connections. The turbine connectors are designed to be Twisted ON and Twisted OFF. This way you never break a RCA female end. If you try to just pull them on or push them on without twisting, this is where damage can occur. Overkill? Maybe but the engineers are Monstercable said this is how we achieve a air tight seal between the RCA Male and RCA Female connector. Again overkill? Maybe. I know it works and they don't fall off when you move around your Amp or CD player. Those cables stay on.
You know one thing I miss working with Monster even over the nice banana plugs they made is the fact they use a high strand count and their cables are flexible. I'm so tired of working with solid core cables, heavy non wanting to bend HDMI cables etc. It sucks when your wiring up a rack and the cables fight you. Forget about high end power cords, they are the worse and most of the time due to the stupid weight, they can easily just fall out. I'm all out on all of it.Dan
Why do we need an air tight seal on RCA cables again?
According to the engineers at Monster, this keeps corrosion out and keeps a purity contact. When air gets in there, it can degrade the signal, not my words , theirs from memory.
If you ask me if that is important? Well no one else does that and I have had IC's from so many brands and Monster is the only ones who worry about such things. I guess it could be an interesting conversation?Dan
A Monster Cable Turbine connector is a patented, high-performance connector, often 24k gold-plated, known for its unique helical or "turbine" design, providing enhanced signal transfer, corrosion resistance, and a secure, air-tight fit for audio/video interconnects, used in various Monster products from RCA cables to headphone jacks, featuring features like split-tip center pins and compression for superior performance.
These are the words from Monster on this matter, not my wordsDan
By the way if anyone comes across any of these, I'll buy them. They are by far the very best banana plugs I have ever used to date. Sure they are TWIST design and working with cables who wind clockwise instead of like Monster counter clockwise can be slightly tricky to some, but they grip very well, they stay on and the twist makes them incredibly strong and super easy to terminate bare wire.Dan
They probably have to be airtight, especially after you twist them off a few times and ruin the plating. I never have a problem with the furutech locking banana and RCA plugs.
If your design requires you to train people on how to use your RCA cables so that they don’t damage their equipment, then I submit that your design is the problem.
I have used RCA cables from AQ, Kimber, MIT, Signal, Doug’s, and yes, Monster (and others too, I’m sure). I have NEVER experienced an RCA cable “fall off” when moving my equipment around. Perhaps though, that’s because I tend to unhook cables when I move gear around. That said, if I WERE to move gear around with cables attached, I’d much rather have them “fall off” than rip the connector shield off the RCA Jack…Why do we need an air tight seal on RCA cables again?
Corrosion? On 24k gold plated connections? Further, no matter how tight the RCA fits, I seriously doubt you could ever approach “air tight”.
Look - I know you’re defending Monster because of your background, and I get it - I remember wading through all the dealer hype about Monster back in the day - and yea, it worked on me in my early days in the hobby. I still have a tote full of monster stuff, and my front 3 HT speakers are wired with the “Z series” (I think?). I’m not saying that Monster is necessarily bad - but the tightness of their RCA cables is a known issue, and blaming the consumer is at the very least lazy…
I think I have some of these floating around in the bottom of one of my totes - BUT, I know that the rubber insulators are probably shot (they tended to degrade over time). Are you interested in just the metal bananas?“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
Mantis, which "Bryn Mawr then Tweeter" were you at? I used to frequent the ones in Townson, Dundalk and Columbia MD. My RTA11TLs came from the one on Reisterstown Rd but I think that was the only time.Stan
Main 2ch:
HT:
Other stuff:
This is what I found in my tote - they’re yours if you want them…. Shoot me a PM…
I haven't had any issues with Monster connections, but I also haven't used any of the higher end RCA terminated interconnects. I've mostly used their lower end store stuff that was bought in the late 90s. I preferred Audiquest for audio signal interconnects and never had any issues with those either, other than failing 'cold welds' on the cable/RCA connection. Found out that it's not easy to get AQ to honor their "lifetime" warranty. I have used monster bananas and I don't think they are better/worse than anything else. Over the years, I've swayed away from bananas in my 2-ch system, but that's all I use in my HT systems, which I don't sweat over as much.
Actually I'm not defending them, just stating my experience , my training and I personally never had an issue, but again like I said I was trained in the ways of the turbine connector. I got a box of them in my basement.The single biggest problem with Monster ICs (especially the “higher end” ones) is the fact that they suffer from significant under-spec in their dimensions, which leads to ridiculously tight connections, and ultimately costly damage. I can’t tell you how many RCA jacks I have replaced for people over the years, due to the shields being pulled free of the gear with the interconnect cable. In every single case, it was Monster Cable. Every one. I know you can just jamb the shield back over the Jack and hope for the best, but to fix it correctly, you need a new RCA block that meets spec, and it needs to be soldered to the PCB.
I agree with you about how tight they are, they where issues with DIY people ripping off their RCA connectors on their amps or AVR's and Monster should have maybe if they really believed that it was necessary to have such a tight connection, maybe do like WBT did and make them a twist lock that could be unlocked or make consumer grade models, which they did and only release the Turbine connectors to trained Installers. I'm not even sure if any of that makes any sense other than I actually do agree with the flaw in their connectors.
Dan
Sure, Let me know what you want for them and lets make it happen.
Thank manDan
Nice!!,
I actually worked on the MD store back in I think it was 2000 or 2001? There was a Parana Bread nearby we would eat lunch at. I didn't work for that store just help get it setup and remodeled back in the day. I did some store development for them.
I was from Princeton NJ , Lawerenceville store was my main store , Oxford valley was my 2nd store but I served stores all over New Jersey and Pennsylvania. I was a IN Home Audio Video Installer back then for them. It was an awesome place to work. Not to mention they took very good care of us. I really miss those days. I met some great people there.Dan
I use to take those boots off in some builds and leave them on in others. I shrink wrapped the ones on the cables I posted here.Dan
I also fussed about the Monster turbine connectors back in the day but it was true that they had a good death grip even if they produced rolled off and dull sounds once I got more revealing gear.
I learned through trial and error that the best way to put them on and take them off RCA jacks was with the twisting motion and not doing things quickly. They never damaged gear when I was using them. They just didn't perform well once I moved beyond a home theater receiver. Monster could make some really good high end cables. They just chose to focus on the big box stores.
Eventually I got rid of all of my Monster cables in favor of Kimber Hero or Silver Streak products with WBT locking connectors. Way better sound produced from those and I still have them 20+ years later! And would have been more expensive if I hadn't bought most of them used before fakery took over the used cable market. -
I like their banana plugs because they are slightly shorter than the standard length and they grab really well. I don't like a lot of the other banana designs. I'm a huge Audioquest user and have been for decades and I don't prefer their banana jacks. In most speaker binding posts they stick out pretty far, they bend easy and they tarnish over time. If you take a look at my pics closely you will see some tarnish on them. I have these Audioquest wipes that you are supposed to clean the banana plug with from time to time which I hate. According to Audioquest , their connectors are better than all other due to their superior metal quality and purity. I don't give a rats **** about that because due to this so called superior connector, it's so superior I have to maintain it or it will turn basically black over time.
The Monster plugs on those cables look brand new, they came from Tweeter way back in the day.Dan
God the Silver Streaks, I absolutely loved them. I had several pair of them , my system at one point was totally wired Kimber Kable. I had 4TC , 8TC and 8TC 8TC bi wires double runs. I loved them as well. Kimber arguably could be one of it not the very best cables for audio period.
PPJ's and Hero's , hell when the HERO's came out, I was totally obsessed with those cables and purchased many pairs. Got I miss being into cables like that. I enjoyed just sitting behind my rack and re wiring it.
Dan
I do NOT like Spade connectors at all, I hate them . BUT Kimber Spades, these ones are awesome. Want to talk about grip? They are the very best Spade I have ever used and I have connect 36k Transparent cables Opus ones and many ultra high end cables. These spades the Post masters by Kimber actually work flawlessly.
Dan
I get it. The Monster are possibly better, but for bananas in my HT, I've only had one type that I hated, and that was some cheap twist locking type that always cold welded itself inside and was a bear to pull out. I threw those all away after a year or two once I discovered how bad they were. Probably some cheap Chinese metallurgy. Most of the other sets I've owned have worked just fine. Most of the time (since 2012 or so), my theater setups go years with very little change out. -
We tried some of the monoprice bananas , these one
shttps://www.amazon.com/Monoprice-Plated-Speaker-Banana-Plugs/dp/B001I4UO3U/ref=asc_df_B001I4UO3U?tag=bingshoppinga-20&linkCode=df0&hvadid=80058282090469&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=94731&hvtargid=pla-4583657828422249&th=1
These are absolutely HORRIBLE!!!. First off the wire can go through the back of the plug instead of using them as a double banana. They are designed to except a banana plug in the back of the plug. So you are supposed to wire them in the side BUT 90 degrees don't always work and makes a mess. Anyway when you do wire them from the back, the wire , they don't bite down well on the wire and the wire can be easily pulled right out. This is a bad design here.
Now also pay attention to the banana design itself. It's a horrible design that slips over time. It works well maybe when new and we had some out of th bag be loose. They are uncomfortable to work with and I threw them all in the trash. Screw those banana jacks.Dan
The last time I redid my living room 3.1 setup, I went relatively cheap with these from Amazon and I was surprised how good they clamped the wire. Nice feel overall. I'm sure the metal is less than perfect copper, but it is a system that I don't do any critical listening on. They have worked well for 3 years now.
They are the "Deadbolt" series from Sewell.
I think Monster had a line similar to that back in the day and I liked the handful that I used, which is what drew me to the Deadbolt design.
