Is this an example of the common core kids playing, sir?
Viking will be all over that
Probably locked in the bathroom with the Jerkins lotion right now...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I really like Alabama but this cartoon is too good not to post.
"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
SCompRacer wrote: »
“There can be only one…!”“Human beings are born with different capacities. If they are free, they are not equal. And if they are equal, they are not free.”
― Aleksandr Solzhenitsyn -
"Der Self-Satisfiedkrauttenwagen winner at the 2025 California Concours d'Lemons was Andrew Hancock from Fremont, CA with his 1971 VW ThinBug. The car was modified by taking a slice out of the middle of the car lengthwise, turning it into a single wide, tandom seat configuration. The work was exceptionally well done, which just goes to show that Andrew was so preoccupied with whether or not he could, he didn't stop to think if he should. But we are glad he did. A well deserved award."
SCompRacer wrote: »
Just a flesh wound... -
Photo from Venice, LA. Where the Mississippi River meets the Gulf of America
September 1, 2025"Sometimes you have to look to the past to understand where you are going in the future"Harry / Marietta GA -
(ASR)
Frank listening to Altec Lansing speakers:
"Walkaround photo album of my (Oleg Sapunkov) full size 3D printed replica 11 inch Model 1861 Dahlgren Gun.
The complete replica is 4.0 meters (13.1 feet) long, 800 mm (31.5 in) in maximum diameter, 1.0 meters (3.3 feet) at maximum width (with the trunnions). It took 96 kilograms (211 pounds) of PLA to 3D print, with 98 spool changes, each of which was accompanied by a nozzle cleaning procedure using nozzle needles and a cold pull, which took around 20 minutes each time. The replica took a total of 1644 hours to 3D print, or 68.5 days of continuous printer time - not counting the nozzle cleanings, or the electronics enclosure fan cleanings I did for the printer between the completion of each major part."
Must be a large 3D printer.
https://www.facebook.com/search/top?q=oleg sapunkov&__stsd__=eyJwcmltYXJ5Ijp7InR5cGUiOiJUWVBFQUhFQURfUEVPUExFX0VOVElUSUVTIn19
Post edited by SCompRacer onSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
The question...will it fire?Political Correctness'.........defined
President of Club Polk -
To fire it, you have to use 3D printed balls and ammo, and have what you are printing to do it.
SeleniumFalcon wrote: »Frank listening to Altec Lansing speakers:
Most of that generation heard themselves in or near the studio/control room that way.
I will say that the recordings monitored, mixed, or mastered on Altecs do sound very good indeed when played back on Altecs.
EDIT: And a little beyond that generation, too
Oh -- of course -- unless they were RCA artists and/or recording in RCA studios.
Then they heard themselves on RCA LC-1A coaxes -- which are also quite sublime. Many would say even better than Altec Duplexes. Duplexes are easier to find and less expensive today -- but the RCAs are very, very special.
