1153154156158159209
    treitz3 Posts: 20,069
    Is this an example of the common core kids playing, sir?
  • Willow
    Willow Posts: 11,246
    Viking will be all over that
    nooshinjohn Posts: 25,974
    Willow wrote: »
    Probably locked in the bathroom with the Jerkins lotion right now...
    Tony M Posts: 11,680
    edited September 2025
  • I really like Alabama but this cartoon is too good not to post.
    Harry / Marietta GA
    SCompRacer Posts: 9,121
  • daddyjt
    daddyjt Posts: 3,125
    SCompRacer wrote: »
    “There can be only one…!”
    ― Aleksandr Solzhenitsyn
    "Der Self-Satisfiedkrauttenwagen winner at the 2025 California Concours d'Lemons was Andrew Hancock from Fremont, CA with his 1971 VW ThinBug. The car was modified by taking a slice out of the middle of the car lengthwise, turning it into a single wide, tandom seat configuration. The work was exceptionally well done, which just goes to show that Andrew was so preoccupied with whether or not he could, he didn't stop to think if he should. But we are glad he did. A well deserved award."
  • SCompRacer wrote: »
    Just a flesh wound...
  • jdjohn
    jdjohn Posts: 3,377
    Photo from Venice, LA. Where the Mississippi River meets the Gulf of America
    September 1, 2025
    Harry / Marietta GA
    Harry / Marietta GA
    Harry / Marietta GA
  • Frank listening to Altec Lansing speakers:
    "Walkaround photo album of my (Oleg Sapunkov) full size 3D printed replica 11 inch Model 1861 Dahlgren Gun.
    The complete replica is 4.0 meters (13.1 feet) long, 800 mm (31.5 in) in maximum diameter, 1.0 meters (3.3 feet) at maximum width (with the trunnions). It took 96 kilograms (211 pounds) of PLA to 3D print, with 98 spool changes, each of which was accompanied by a nozzle cleaning procedure using nozzle needles and a cold pull, which took around 20 minutes each time. The replica took a total of 1644 hours to 3D print, or 68.5 days of continuous printer time - not counting the nozzle cleanings, or the electronics enclosure fan cleanings I did for the printer between the completion of each major part."
    Must be a large 3D printer.
    https://www.facebook.com/search/top?q=oleg sapunkov&__stsd__=eyJwcmltYXJ5Ijp7InR5cGUiOiJUWVBFQUhFQURfUEVPUExFX0VOVElUSUVTIn19
    Post edited by SCompRacer on
    F1nut Posts: 51,930
    The question...will it fire?
  • bcwsrt
    bcwsrt Posts: 2,478
    Yes, just once!
    Brian
    To fire it, you have to use 3D printed balls and ammo, and have what you are printing to do it. :D
    pitdogg2 Posts: 27,209
    In every direction...
  • daddyjt
    mhardy6647 Posts: 35,192
    Most of that generation heard themselves in or near the studio/control room that way.
    I will say that the recordings monitored, mixed, or mastered on Altecs do sound very good indeed when played back on Altecs. B)
    EDIT: And a little beyond that generation, too
    Oh -- of course -- unless they were RCA artists and/or recording in RCA studios.
    Then they heard themselves on RCA LC-1A coaxes -- which are also quite sublime. Many would say even better than Altec Duplexes. Duplexes are easier to find and less expensive today -- but the RCAs are very, very special. :p
