You’re doing it wrong…
    treitz3 Posts: 20,239
    Wow. That cat has been doing it wrong for some time!
    pitdogg2 Posts: 27,688
    They need some washers......maybe even lock washers.....
    Seems like they could easily triple that cost.....
  • maxward
    maxward Posts: 1,732
    And you can pay in installments.
  • skipshot12
    skipshot12 Posts: 2,114
    SCompRacer wrote: »
    The caption was sewer backing up after high voltage underground mains updated... Mole (trenchless) method used.
    Directional boring does this all the time.
    SCompRacer Posts: 9,215
    edited August 2025
    This is our 1 year anniversary for the sewer backup at the house. Cast iron sewer pipe broken at foundation wall. House was built in 1999. Based on condition of break and the fact tree roots from 15 foot away were growing into break, it could have happened when they were backfilling against foundation with a cat. Over time the pipe settled two - three inches and paper collected at break.
    An outside cleanout was added.
    Unfortunately, I can almost smell that post. I hope you got that dirt up and away from the vinyl siding. You want at minimum a 4" clearance down. FWIW.
    edited August 2025
    That was initial fill, mostly clay. I accelerated the settling by drilling a dozen or more 3" auger holes three feet down and saturating the area with water. That took over a week to dry out. It was like quicksand at first. Once it was solid to walk on, we leveled the fill and scraped the topsoil back then replaced the removed plants. Once we had the appropriate ground level, the guy returned to trim the pipe and glue the cleanout on.
  • daddyjt
    daddyjt Posts: 3,207
    ― Aleksandr Solzhenitsyn
    Viking64 Posts: 7,739
    You can never have enough spare bolts.
  • seeclear
    seeclear Posts: 1,244
    It would take a bit for those fuses to blow!
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,982
    Four years ago Eleven Madison Park, a three-Michelin-starred New York restaurant named best in the world in 2017, shocked the fine-dining sphere with an entirely plant-based menu. This week, its chef and owner, Daniel Humm, announced a U-turn: from mid-Oct, meat and seafood will return at the vaunted Manhattan establishment.
    “Eating together is the essence of who we are, and I’ve learned that to truly champion plant-based cooking, I need to create an environment where everyone feels welcome around the table.”
    Meat-eaters, it seems, were put off by the meatless approach. Humm told the New York Times he hadn’t realized he “would exclude people” by going vegan.
    ___________________________________________
    For comparison sake, here is a Porterhouse Steak from Peter Luger Steak House in Brooklyn that has a long history of serving beef since 1887
    Harry / Marietta GA
    VR3 Posts: 29,661
    edited August 2025
    I'm impressed he achieved 8 years of that plan
  • motorstereo
    motorstereo Posts: 2,401
    VR3 wrote: »
    Undoubtably that 8 year run has a lot to do with it's NY location. They wouldn't have made it 8 weeks in Texas.
    VR3 Posts: 29,661
    I think 8 weeks is a stretch lol 😂
    VR3 Posts: 29,661
    Is that electrical going thru a pocket door?
  • ken brydson
    ken brydson Posts: 9,073
    VR3 wrote: »
    Wise observation grasshopper
    Electric pocket doors? LUXURY!!!!!!
    VR3 Posts: 29,661
    That nose ring... Just imagine what that bad boy looks like under a microscope
  • daddyjt
