Polk magnifi max
bartek_tychy
bartek_tychy Posts: 4
edited May 2025 in Troubleshooting
Hi all,
So i bought the Polk Magnifi Max SR in 2020 and i loved it, but a couple of weeks ago it started to fail. Very strange things:
Power button doesnt work anymore
LED light at the front always orange/amber
No wifi connection
No wired ethernet connection (router only says mac adress but no ip adres)
Google Home sees the device but cant connect.
HDMI audio not working anymore
B
Optical audio is working but puts volume at maximum constantly
Bluetooth audio is working but keeps disconnecting.
Please help me
  • SeleniumFalcon
    SeleniumFalcon Posts: 4,397
    Hello,
    Welcome to the Polk forum. I'll forward your description of the problem to a friend at Polk. Just in case you need a service center where are you living?
  • bartek_tychy
    Hello,
    Thank you very much for your help in this matter, I am from Poland.
  • SeleniumFalcon
    Hello,
    My friend recommended that you contact the Polk dealer where you purchased your soundbar for service.
  • bartek_tychy
    polish official service stated in phone conversation l that there is no possibility of repair. My parents also have Magnifi Max and it is also damaged after 3 years of use, I am disappointed with the quality of polk product and service support.
  • SeleniumFalcon
    I will relay your comments.
  • SeleniumFalcon
    Hello,
    I didn't give you those instructions until May 12th? Anyway, I'll ask him to check on your message.
  • SeleniumFalcon
    Hello,
    He found your message in his spam folder. Two replacement bars are on their way to you, they should ship on Monday.
  • bartek_tychy
    Hello,
    hello, soundbars are already with me, thank you very much for your help and support. I can enjoy the sound of Magnifi Max again. Service at the highest level, as befits a leader in the audio industry, best regards.
  • SeleniumFalcon
    edited June 2025
    Hello,
    Thanks for letting us know. Take care and enjoy your Polks!
  • Kakashi03
    Kakashi03 Posts: 6
    Hello,
    hi i have themsame issue bought the magnifi max around 2021 bute right now it's stuck on blinking white light..
