Polk magnifi max
bartek_tychy
Hi all,
So i bought the Polk Magnifi Max SR in 2020 and i loved it, but a couple of weeks ago it started to fail. Very strange things:
Power button doesnt work anymore
LED light at the front always orange/amber
No wifi connection
No wired ethernet connection (router only says mac adress but no ip adres)
Google Home sees the device but cant connect.
HDMI audio not working anymore
B
Optical audio is working but puts volume at maximum constantly
Bluetooth audio is working but keeps disconnecting.
Please help me
No wifi connection
B
Please help me
Hello,
Welcome to the Polk forum. I'll forward your description of the problem to a friend at Polk. Just in case you need a service center where are you living? -
SeleniumFalcon wrote: »Hello,
Thank you very much for your help in this matter, I am from Poland. -
Hello,
My friend recommended that you contact the Polk dealer where you purchased your soundbar for service. -
polish official service stated in phone conversation l that there is no possibility of repair. My parents also have Magnifi Max and it is also damaged after 3 years of use, I am disappointed with the quality of polk product and service support.
I will relay your comments.
Hello,
I didn't give you those instructions until May 12th? Anyway, I'll ask him to check on your message. -
Hello,
He found your message in his spam folder. Two replacement bars are on their way to you, they should ship on Monday. -
hello, soundbars are already with me, thank you very much for your help and support. I can enjoy the sound of Magnifi Max again. Service at the highest level, as befits a leader in the audio industry, best regards. -
Hello,
Thanks for letting us know. Take care and enjoy your Polks! -
hi i have themsame issue bought the magnifi max around 2021 bute right now it's stuck on blinking white light..
