my polk magnifi max sr
mitrawellnes
my polk magnifi max sr has no sound output after sometime working.
Best Answers
my polk magnifi max sr has no sound output after sometime working -
Can you tell me where you live?
Answers
Hello,
Welcome to the Polk forum. The problem is either with the components that are providing the signal to the soundbar. Or, the soundbar itself. What is the soundbar connected to? Please provide as much detail as possible. -
Well if the factory reset doesn't help then 100% it's a hardware problem
After working for a while, there is no sound, whether it is HDMI, Bluetooth, or any other input.
SeleniumFalcon wrote: »Can you tell me where you live?
India, kerala state, Chalakudy city -
Thank you for the information, I will ask a friend at Polk for recommendations on what you should do to fix the problem.
He has recommended that you check the power supply for the soundbar. If possible use a volt/ohm meter to measure 19 volts DC.
If this is not the problem, you can refer him to PROFX for assistance and they are an authorized Polk Audio dealer.
https://profx.com/
