Fix or Replace PSW111
My 2017 vintage PSW111 keeps blowing fuses. I’ve seen other posts about this, but I’m well out of warranty. Worth fixing, or just replace it?
Best Answer
Answers
    F1nut Posts: 52,368
    Replace it.
  • bcllewellyn
    Thanks for your feedback. Do you have a recommendation for a better sub?
    pitdogg2 Posts: 27,857
    HSU, SVS and Velodyne are a good start.
    In no particular order FWIW.
    treitz3 Posts: 20,341
    Agreed on replacing it, FWIW. What type of budget were you thinking?
    F1nut Posts: 52,368
    Add REL and Rythmik to the list.
  • bcllewellyn
    Well, I was thinking under $300. Maybe that’s not realistic.
    No, it's not. You are stuck to local and used, at that price point, unfortunately.
  • bcllewellyn
    Ok, thanks. I’ll look into the ones you’ve all recommended.
