Fix or Replace PSW111
My 2017 vintage PSW111 keeps blowing fuses. I’ve seen other posts about this, but I’m well out of warranty. Worth fixing, or just replace it?
Best Answer
Answers
    Replace it.
  • Thanks for your feedback. Do you have a recommendation for a better sub?
  • HSU, SVS and Velodyne are a good start.
    In no particular order FWIW.
  • Agreed on replacing it, FWIW. What type of budget were you thinking?
    Add REL and Rythmik to the list.
  • Well, I was thinking under $300. Maybe that’s not realistic.
  • No, it's not. You are stuck to local and used, at that price point, unfortunately.
  • Ok, thanks. I’ll look into the ones you’ve all recommended.
