Feel the hate thread
1…181920212224»
  • LisaBen
    I hate being told I must be a bot in my first posts here. But at least I'm not a post ****.
    Clipdat Posts: 13,107
    Good to know that you're still salty about that.
    mhardy6647 Posts: 35,562
    xschop wrote: »
    I hate the search feature here.
    It is miserable -- so I usually just use google to search this forum. :blush:
    treitz3 Posts: 20,367
    Yup. Me too. Much easier.
  • ChrisD06
    ChrisD06 Posts: 929
    ChrisD06 wrote: »
    I hate painting a room and realizing I forgot to remove the lint from the roller, and now I have to individually pick the lint off of the wall which dried in (the stuff I didn't pick off while painting) before applying the second coat. And then I realized that I did 3 walls perfectly but the fourth was a little too thin.
    Okay the second coat seems to have made the wall look essentially flawless though there are still minor imperfections.
    Ironically, it looks better than the paint job done by the contracted painters in '08 when they built the house. So I'll take that one with pride
    My gear:
    • TCL 75QM7K TV
    • Onyko TX-NR656 AVR
    • RT3000p Fronts
    • CS1000p Center
    • RT35 Side Surrounds
    • RT35 Rear Surrounds
  • ChrisD06
    ChrisD06 Posts: 929
    Now I hate uneven subfloor seams
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
    nooshinjohn Posts: 26,184
    LisaBen wrote: »
    Searching for snarky reply that will not get me banned.... nope, I got nuthin'.
    edited January 2024
    ChrisD06 wrote: »
    https://youtu.be/Be886Ezi30g?t=18
    Hammer time!
  • ChrisD06
    ChrisD06 Posts: 929
    treitz3 wrote: »
    ChrisD06 wrote: »
    Hammer time!
    Yeah I've been going to town but I think it's just swelling on the edges or the OSB so it should be a quick and easy fix. Thankfully it doesn't look like I'll need underlayment.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • invalid
    invalid Posts: 1,560
    ChrisD06 wrote: »
    treitz3 wrote: »
    ChrisD06 wrote: »
    Hammer time!
    I would use underlayment if I were doing that job, it's not that expensive and it will be a better job.
  • ChrisD06
    ChrisD06 Posts: 929
    invalid wrote: »
    ChrisD06 wrote: »
    treitz3 wrote: »
    ChrisD06 wrote: »
    Hammer time!
    I was going to but I managed to flatten it in about an hour with a sander, some screws, and sinking the protruding nails. Half the floor is installed and it's perfectly flat. Starting on the other half very soon.
    My gear:
    • TCL 75QM7K TV
    • RT3000p Fronts
    • CS1000p Center
  • soundfreak1
    soundfreak1 Posts: 3,414
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    xschop Posts: 5,932
    xschop wrote: »
    I also hate the auto-correct here too. I think it taunts you.
    msg Posts: 10,650
    NOOOO! :D
    pitdogg2 Posts: 27,921
    Thank god they weren't wrong time bass port exhaust expellers
  • aprazer402
    aprazer402 Posts: 3,469
    msg wrote: »
    They called this guy into the boss's office afterward and Schiit-canned him for it.
    I was not aware you worked there. Can you get us a discount?
