Polk Magnifi Max SR
Hi all,
So i bought the Polk Magnifi Max SR in 2020 and i loved it, but a couple of weeks ago it started to fail. Very strange things:
  • Power button doesnt work anymore
  • LED light at the front always orange/amber
  • No wifi connection
  • No wired ethernet connection (router only says mac adress but no ip adres)
  • Google Home sees the device but cant connect.
  • HDMI audio not working anymore
  • Bluetooth audio is working but puts volume at maximum constantly
  • Subwoofer is not working anymore and only "pops"
  • Resetting doesnt do anything (no beeps at all)
I read a lot on the internet but there are a lot of reviews. Some fixed by updates, some fixed by resetting. Seems there are a lot of issues with the Magnifi Max. Is there anything i can do other then contacting support (already filed a ticket btw)? Is there anything possible with the service usb port for example?
