Toslink cable, which one?
danger boy
Ok. i want to upgrade my Toslink optical cable. and I don't want to spend over $75. can anyone recommend a good thick optical cable?
what kind do you all use?
PolkFest 2012, who's going>?
Post edited by danger boy on
As long as it's a high quality cable , brand here I found doesn't make any difference. I have used Kimber Kable , Transparent , Monster and even a cheap one from Mitsubishi (which was the worse out of the bunch)
Monsters Optical cables are well built. Pro Solutions also makes a nice optical cable.
DanDan
Go with the cable that gives the most snug fit. I find that some that are too small, almost fall out when touched or moved around.
This is suppose to be a universal fitting, but brands vary.
DGHT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
http://www.cobaltcable.com/product/toslink_cable.htm
I can't check right now because the shop is under maintainance, but I think the "newsletter" coupon for 30% off should still work. But if not, it's still only $53 and they ship for free. 90 day satisfaction guarantee. Great build quality...Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Check these out, excellant quality and good price, highly recommened. And they're glass, not plastic.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5732495139Larry -
I find AR makes a nice tight fit !!
Larry,
thanks for the link. I went ahead and ordered one from the guy.... from the reviews his cables have gotten.. it sounds like it would be worth a try. Cost seemed reasonable too.
thanks, alPolkFest 2012, who's going>?
Check out www.accessories4less.com, they have a great sale on AR cables.Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's -
ARE YOU SERIOUS? I'm not really sure I'd trust a guy who doesn't even know how to hook up electronics... but that's just me.Ebay auction
The series utilize glass fiber optic conductors and precision connectors to reduce digital jitter for a dramatic upgrade over conventional toslink optical cables, which utilize plastic fiber optic conductors. Glass fiber optic transmission allows superior high resolution, amazing clarity reproduction, ultra spatial effects and dynamic impact. It's ideal for use with DVD, DVD Audio, SACD, CD, D-VHS, game console, S/PDIF, Dolby DigitalR and DTSR professional audio applications.Never kick a fresh **** on a hot day.
..Originally posted by Maurice
Maurice, i think you need to update your link. AC4L.com
cherrioPolkFest 2012, who's going>?
An updated link does help.;)Everytime I think I'm out, THEY PULL ME BACK IN!!!!!!
Polk 70's,40,30's
Velo DLS 3500 Sub
JVC 61" HD-ILA
Sony DA4ES AVR
Oppo 981 DVD
Sony CDP-CX235 CD
Signal Bi-wires
AR ProII IC's
