Must try MOD - Foam inside the stamped steel baskets - YES!
167891012»
  • Gardenstater
    Gardenstater Posts: 4,781
    edited November 2024
    odcics2 wrote: »
    The magnet and surrounding area is much larger than the outer basket with the 4 holes. Foam helps, but there is a lot or room for improvement left on the table.
    I got my question answered regarding whether or not CSD would be a way to measure this and it turns out it just might be. Unfortunately CLIO isn't in my budget in the near future:
    https://www.parts-express.com/Audiomatica-CLIO-Pocket-Version-2-Personal-Acoustic-Measurement-System-390-900?quantity=1
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • gp4jesus
    gp4jesus Posts: 2,019
    gp4jesus wrote: »
    Interesting…
    One of the higher-end tire manufacturers, attempting to attenuate ~200hz road noise using a similar execution of foam on the interior
    While shopping for tires (daughter’s Corolla) I saw this thinking “I MUST post this for George et al:”
    “… 9dB - that is how much our ContiSilent™ can reduce the sound of road noise inside your car. An inner tyre absorber, made of polyurethane foam, is attached to the inner surface of the tyre tread, to cushion the road.” Different material and frequency range target but answers Hansvelton’s question. As I said elsewhere: Foaming my LC*Rs’ mids significantly reduced their upper midrange “bark.”
    *accomplished after original comment and Rob’s Plug mod
    Buon Felice Natale and “Joyous listening!”
    *all connected w/Premiere ICs
  • For some reason your post reminded me of Ellen Barkin 🤣
    https://www.youtube.com/watch?v=WXzsVDl08A4
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited December 2024
    But seriously, pretty different application and much thicker so absorbs lower frequencies and vibrations like you get inside a tire, but cool just the same.
    Reminds me a little of my Tannus Armor inserts on my mountain bike tires. Quieter but mainly for flat prevention. Used to get a couple every year and haven't had one in the last 10 years. It was always thorns believe it or not!
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
