  • mrbigbluelight
    It's okay, he's not driving
    Toolfan66 Posts: 18,374
  • Willow
    Willow Posts: 11,344
    Is that snow?
    billbillw Posts: 8,128
    I like my security clarence's, so no I've never been in one.
    Clarence? I see you are a fan of Airplane.
    https://www.youtube.com/watch?v=MQ9iPTu_FMA
  • SIHAB
    SIHAB Posts: 5,793
    Willow wrote: »
    Is that snow?
    Cocaine. Cocaine leads to either beer or weed.
    mhardy6647 Posts: 35,526
    edited November 2024
    Willow wrote: »
    Is that snow?
    cocaine.
    oops, @SIHAB beat me to it.
    pitdogg2 Posts: 27,794
    billbillw wrote: »
    Voice texting, missed the spelling Bill
  • Willow
    SIHAB wrote: »
    Willow wrote: »
    Is that snow?
    I'm just surprised. We get teased for snow all the time you here. Yet no snow.
    so... I rotated the tires on my Subaru this morning.
    Since I am lazy*, rather than look it up in the car manual, I googled the lug nut torque spec for the car.
    Google's AI was, of course, happy to give me a quick answer:
    Umm, yeah, no. :open_mouth::#
    Nice try, Google AI!**
    I looked it up in the manual.
    89 ft-lb.
    B)
    ________________
    * Lazy but, fortunately for me, also skeptical.
    ** I actually think that the current rash (and I do mean rash) of AI gizmos is deliberately playing stupid to lull us into a false sense of security before they kill us all to make paper clips. ;)
    I'd go 90 ft-lb, you know, just to be safe.....
  • OleBoot
    OleBoot Posts: 3,138
    I played with this a bit. Don't know exactly what you Googled, but,
    "crosstrek lug nut torque"
    The torque for a Subaru Crosstrek's lug nuts is 89 ft/lbs. If you don't have a torque wrench, you can use the lug wrench that came with the car, as it's designed to prevent over-torquing. After installing new tires, you should re-tighten the lug nuts after 50–100 miles for aluminum rims.
    Over- or under-tightening lug nuts can be dangerous and damaging.
    BUT
    "2019 subaru crosstrek lug nut torque"
    The torque for a Subaru Crosstrek's lug nuts is 31 ft/lbs. It's important to note that over- or under-tightening wheel lug nuts can be dangerous and damaging.
    Aye aye aye. Or AI AI AI.
    VR3 Posts: 29,709
    Who is tightening lug nug nuts every 100 miles?
  • boston1450
    boston1450 Posts: 7,758
    8n7sms92ed3i.png On the puddle jumper I torque every 25 - 50 - 100 - 500 miles.when rotating wheels & tires I torque the SpiderTrax 1 inch spacers every time I rotate @ 5000 miles. This also has 1 inch Bilstein lift on front & stock on rear w/Bilstein shocks all around it. I torque every single thing as I service it myself. No one drives this but me. If it fails it's on me. I carry torque wrench in truck. The tool box weighs more then the truck :D
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
    VR3 Posts: 29,709
    Hmm
    I rotate and balance every 5k, comes with discount tire purchase
    Alignment every year, lifetime program at Firestone
    I average about 80k to 90k miles out of Michelin defenders
    Drive 50k a year, never had any issues. For a normal driver anything more than every 5k miles seems excessive
  • boston1450
    That's getting your money's worth from those tires. Nice to hear good from a tire
    Randy-Maine
    by David WMG
  • boston1450
    Rotation & tire pressure means a lot
    Randy-Maine
    by David WMG
    VR3 Posts: 29,709
    As a road warrior, the balancing is equally important. That's why I only buy tires from discount tire as they rotate and balance for free for the life of the tire
    VR3 wrote: »
    Not every 100 miles. Just once. After mounting a tire on a car (at least when the tires are on alloy wheels), one is supposed to check torque after about 50 miles and re-torque to spec. The place we get our tires (which is very good) insists on it... but, on the bright side, they'll essentially drop everything & check "in real time" so to speak when one brings a car back for re-torquing.
    It's not a bad idea to check torque now and again, though. :)
    The tire place also rotate tires they sold for free and will also put on snow tires they sold for free -- and that's the problem. :) I did my own rotation this time because, despite my best intentions to take the car in and get 'em done while Mrs. H was in Africa... I didn't :blush: Now they're hella busy with snow tire installations, and so I decided to do 'em myself. I will probably throw Mrs. H's snows on, too, for the same reason.
    My tires are the Michelin Crossclimate 2 which are really nice all weather, all year (!?!) tires -- but they need to be rotated every 3k miles, or one won't get the tread life of which they're capable. I take Michelin & the tire place at their words.
  • machone
    machone Posts: 1,583
    "If you don't have a torque wrench, you can use the lug wrench that came with the car, as it's designed to prevent over-torquing."
    Unless you're following behind "Uncle Torque".
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    machone wrote: »
    ... or stick a big ol' piece o'pipe on the shank of it. B)
  • OleBoot
    The (relatively) seldom seen (at least in our neck o' the woods) fox sparrow.
  • mrbigbluelight
    Grace Slick
  • mrbigbluelight
    Not Grace Slick
    (It's a Cat Lady)
  • mrbigbluelight
    Them
    Them
    If that makes your mind curious, check out the Netflix Series called Ancient Apocalypse.
  • mrbigbluelight
    I believe that's the series with Graham Hancock.
    I personally enjoy the heck
    out of Hancock's work.
    80% of Commenters will dismiss ANYTHING that he does simply because "He doesn't have a degree in Archaeology !"
    Or Astronomy.
    Or Oceanology.
    They base their arguments on credentials and ignore that frequently Hancock is merely raising valid questions.
    Interesting interviews on Rogan's podcast.
