Must try MOD - Foam inside the stamped steel baskets - YES!
167891012»
  • Gardenstater
    Gardenstater Posts: 4,787
    edited November 2024
    odcics2 wrote: »
    The magnet and surrounding area is much larger than the outer basket with the 4 holes. Foam helps, but there is a lot or room for improvement left on the table.
    I got my question answered regarding whether or not CSD would be a way to measure this and it turns out it just might be. Unfortunately CLIO isn't in my budget in the near future:
    https://www.parts-express.com/Audiomatica-CLIO-Pocket-Version-2-Personal-Acoustic-Measurement-System-390-900?quantity=1
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • gp4jesus
    gp4jesus Posts: 2,019
    gp4jesus wrote: »
    Interesting…
    One of the higher-end tire manufacturers, attempting to attenuate ~200hz road noise using a similar execution of foam on the interior
    While shopping for tires (daughter’s Corolla) I saw this thinking “I MUST post this for George et al:”
    “… 9dB - that is how much our ContiSilent™ can reduce the sound of road noise inside your car. An inner tyre absorber, made of polyurethane foam, is attached to the inner surface of the tyre tread, to cushion the road.” Different material and frequency range target but answers Hansvelton’s question. As I said elsewhere: Foaming my LC*Rs’ mids significantly reduced their upper midrange “bark.”
    *accomplished after original comment and Rob’s Plug mod
    Buon Felice Natale and “Joyous listening!”
    *all connected w/Premiere ICs
  • For some reason your post reminded me of Ellen Barkin 🤣
    https://www.youtube.com/watch?v=WXzsVDl08A4
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • Gardenstater
    edited December 2024
    But seriously, pretty different application and much thicker so absorbs lower frequencies and vibrations like you get inside a tire, but cool just the same.
    Reminds me a little of my Tannus Armor inserts on my mountain bike tires. Quieter but mainly for flat prevention. Used to get a couple every year and haven't had one in the last 10 years. It was always thorns believe it or not!
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
    xschop Posts: 5,295
    Bump for Vsat. and another newbie. Full mods or go home.
  • VSAT88
    VSAT88 Posts: 1,312
    xschop wrote: »
    Lol. Santa's slippin', I still haven't gotten the 16uf Black Dragon caps that I asked for.
    DANG! Was I supposed to talk to Santa about these Rob?
  • VSAT88
    VSAT88 Posts: 1,312
    I have used the Armacell on the outside of a few sets of the Polk MW basket myself. Did not have any trouble with it. Now, after I install my phase plugs I am trying this too. Just installed Silver Dragon face plates instead of the Made In Red China factory flimsy one on my SDA 2b's. Oh how nice to tighten the tweeter up without a huge bend in the corner of every one of them. They look and sound fantastic! One of the best mods yet! Even my dogs Raggi and Me Pal agreed. Soon as I was done installing them and turned on the music they ran right in! So you may wonder, where are the speakers that's one crazy room! Its my "office" where I retire and work on everything. The other image is of Me Pal sticking his tongue out at anyone who do not have the Silver Dragon face plates yet and Raggi Head Banging to Metallica $9.98 CD and me. LOL!! u7xmicsqxbyr.jpg
    xschop Posts: 5,295
    Lol. Best review ever.
    Did you use black rouge polish on those?
  • VSAT88
    VSAT88 Posts: 1,312
    Silver Dragon Polish... But, it was cold here last night! I did not do anything but a very quick job. Like I said, office setup. Looks Peachy Keen to me here in Greenbow Al. Karen Dalton never sounded so good.
    xschop Posts: 5,295
    VSAT88 wrote: »
    xschop wrote: »
    No worries, I deleted them and ran the DC28F silks.
  • VSAT88
    VSAT88 Posts: 1,312
    I do recall seeing you some caps one time but I sure don't recall talking to you about any 16uF's. Why didn't you text or call me and curse me out or something man! Thanks for letting me off the hook so easily but never expect the same thing from me! Lol! I would have called you and bugged your @ss.
    xschop Posts: 5,295
    That was many moons ago when I decided to go with the 28mm domes in the 8TLs also.
    I simply cut the 16uF's out the circuit.
    May need a set of 13.5uf soon if the dragon master has any stashed in the dungeon lol
