Polk LSI15 - losing volume / SPL output after few hours of playback
Hi, my polk LSI15's seem to lose volume with continued play time on my tube amp ( 4 ohm connection ) - they start off reasonably well but then after playing for a few hours, seem to quieten down about 3 -6db vs before. I have them turned off for now, will check again in the morning but I have a dats audio V2 and took some impedance measurements - speaker dips down to 3 ohms at 100Hz and also dips down to 3 ohm in the 2-3KHz range - Is that normal? Has anyone plotted these to see how low an impedance they go? They are rated at 4 ohms but they also seem to go up to 20 ohms between 20 Hz and again at some higher frequencies.. Will try to share the impedance plot in next post.
