Focal JM Lab Mezzo Utopia modification
{Hello? I would like to know the polarity of the speakers focal mezzo !!!}
Hello, I would like to know the polarity of the speakers focal mezzo !!!
WHAT??
Louder we can't hear you, try another 30 times....
It sounds like you have them set up in a room with a lot of echo.
They identify as in phase- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Stay safe Trey, gonna get soggy I see.
I'm only out of phase on Tuesday- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sorry, the message was not sent. The site was giving an error. How is the phase connected to the speakers twitter and the mid-bass of the focal mezzo?
In phase across the board- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I looked at that 1028Be has an antiphase connected to the tweeter and the midbass. Maybe mezzo has the same thing?
Good sir.
Every driver is in phase. The negative of each driver returns to ground.
No drivers are out of phase to the other.
You will connect the positive wire to the positive terminal and the negative to negative on all drivers.
I hope this helps
All the best- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thank you. Do capacitors connected in parallel affect the sound phase? Is there a difference between one capacitor or two connected in parallel?
